Basic macro questions
- thet
I have some basic questions on macro usage in linuxcnc.
Is it possible to execute gcode within self defined macros (e.g. M101)? All examples I found searching the web are executing hal_cmd or other bash code. But no example showing how to let's say move the cnc mill in a rectangle shape.
I found out, that I could do such using python and import linuxcnc module and execute a mdi command. But that does only work as a single G-code line in MDI mode and not when I use that M-code within a ngc file.
Can you give me a hint how to use macros properly?
Or maybe macros aren't the best way to do that?
Ubuntu 10 LTS version
with axis 2.5
- BigJohnT
- Thank you received: 994
JT
- newbynobi
- Thank you received: 394
For details see the corresponding WIKI page.
Norbert
- BigJohnT
You can add macros to gmoccapy, similar to touchy's way.
A macro is nothing else than a ngc-file. You are able to execute complete CNC programs in MDI mode, by just pushing one button.
To do so, you have to add a section like so:
[MACROS]
MACRO = i_am_lost
JT
- ArcEye
- Thank you received: 240
Make a file called rect.ngc which contains something like
o<rect> sub
GOO X0 Y0 Z2
GO0 Z0.1
G01 Z-0.1
GO1 X90 Y90
G01 X180 Y0
G01 X90 Y-90
G01 X0 YO
G00 Z2
o<rect> endsubThen call it in your code with
o<rect> call
- thet
The subroutine solution (ngc o-code) worked for me.
... for now
Now I will dig a little bit deeper in python based subroutines (found some python code that looked like subs).
- newbynobi
you are right, but you can run a complete subroutine in gmoccapy or touchy by just pressing one button.
I thought, that is what he weant's.
And I have to to also some advertising for my GUI
Norbert
- BigJohnT
JT
