Machine Coordinates from G-Code, #<_hal[]> support
- Thank you received: 7483
30 Mar 2019 00:50 #129944
Replied by tommylight on topic Machine Coordinates from G-Code, #<_hal[]> support
Is this probing for plasma ?
- spicer
- Thank you received: 126
30 Mar 2019 01:28 - 30 Mar 2019 04:47 #129948
by spicer
Replied by spicer on topic Machine Coordinates from G-Code, #<_hal[]> support
Yes.
Test video you see here:
www.xup.in/dl,15200380/plasma_kopf.MOV/
The hole on top is for the 12mm capacitive (or inductive) sensor.
I work with 2 dimensions ^^
This is very easy for the user.
It have 2 buttons. One for XY zeroing,
other for probing.
The solution of the problem "MDI mode" is here
forum.linuxcnc.org/24-hal-components/363...i-mdi-command#129952
measuretool.ngc
o<measuretool> sub
; setup
G49 (cancel tool lengths)
G91 (incremental mode)
G28.1 (copy absolute coordinates into #5161-#5169)
#1002=[-#5163] (probe depth)
; measure
G38.2 Z#1002 F20 (Z probe)
G92 Z-2.05 (distance switch_on to Workpiece surface)
G90
G0 Z1 (after probing move to 1mm up from workpiece)
o<measuretool> endsub
M2This is very easy for the user.
other for probing.
Last edit: 30 Mar 2019 04:47 by spicer.
- pl7i92
- Thank you received: 358
30 Mar 2019 08:19 #129957
by pl7i92
Replied by pl7i92 on topic Machine Coordinates from G-Code, #<_hal[]> support
why at all does your plasma use XY Zeroing
i got on all 4 Plasmas we use a Fix XY zero wher the sheet is fixed to and all programms use this zero
ok i only got 1x1meter sheets no inlays
but the Homing refers to this point and then Z touchoff as you do it
i
the Fix Zero makes life very easy
one button press and then run
i
30 Mar 2019 11:01 #129966
Why are you not using one of the configs that have automated probe in hal ?
forum.linuxcnc.org/plasma-laser/34978-th...-with-how-to?start=0
Choose one depending on your hardware.
- spicer
30 Mar 2019 14:36 #129970
by spicer
Mostly we will not use XY-zeroing.
This is just so that you have the possibility, if perhaps even a workpiece is not in the corner.
@tommylight
That would have been a possibility, of course.
I have not seen the thread before.
i
@tommylight
- pl7i92
30 Mar 2019 16:23 #129976
by pl7i92
if you are on THC
toms config changes on every M3 is a waist of time
with 100 M3 in files it is a nightmare on theroing up
Personal expirience
Personal expirience
30 Mar 2019 22:05 #129999
It does not "changes on every M3", it does probe for material on every M3.
Here that is a must as the material used here is the bottom quality, so it warps a lot. Also i have some very fast Z axis that can do 6000mm per minute and have 28 cm travel !
Probe time = 1 second
- pl7i92
01 Apr 2019 06:02 #130077
by pl7i92
I have seen people with 5mm bent table not doing probing at all as the thc jumps in and goes to the given Voltige down
within a mm of travel at 6m/min
even on Torch fire-ring startup at 5mm from material
Time to create page: 0.126 seconds
