- Thank you received: 358
Machine Coordinates from G-Code, #<_hal[]> support
- pl7i92
i got on all 4 Plasmas we use a Fix XY zero wher the sheet is fixed to and all programms use this zero
ok i only got 1x1meter sheets no inlays
but the Homing refers to this point and then Z touchoff as you do it
i
the Fix Zero makes life very easy
one button press and then run
- Thank you received: 7491
forum.linuxcnc.org/plasma-laser/34978-th...-with-how-to?start=0
Choose one depending on your hardware.
- spicer
- Thank you received: 126
pl7i92 wrote: why at all does your plasma use XY Zeroing
i
Mostly we will not use XY-zeroing.
This is just so that you have the possibility, if perhaps even a workpiece is not in the corner.
@tommylight
That would have been a possibility, of course.
I have not seen the thread before.
- pl7i92
toms config changes on every M3 is a waist of time
with 100 M3 in files it is a nightmare on theroing up
Personal expirience
:ohmy:spicer wrote: I have not seen the thread before.
pl7i92 wrote: toms config changes on every M3 is a waist of time
It does not "changes on every M3", it does probe for material on every M3.
Here that is a must as the material used here is the bottom quality, so it warps a lot. Also i have some very fast Z axis that can do 6000mm per minute and have 28 cm travel !
- pl7i92
within a mm of travel at 6m/min
even on Torch fire-ring startup at 5mm from material
