[SOLVED] Requested tool not found in tooltable
12 Oct 2013 00:21 - 10 Jan 2014 00:04 #39778 by minitreintje
Hello,
I want to open a drill file of PCBGCODE (an ULP for EAGLE to generate Gcode from the PCB's) but I got this error:
Requested tool 5 not found in tooltable.
I add the tool in the tooltable with number 5, save it and reopened it again.
But I got the same error.
Somebody who can help?
The file for engraving the PCB works properly...
minitreintje
Last edit: 10 Jan 2014 00:04 by minitreintje.
12 Oct 2013 00:37 #39779 by cncbasher
Replied by cncbasher on topic Requested tool not found in tooltable
you'll need to add a tool no 6 also as your gcode shows T6 so to cover everything make a dummy tool table to cover T7 also
that hopefully should do it .
12 Oct 2013 00:41 #39780 by minitreintje
Replied by minitreintje on topic Requested tool not found in tooltable
Thanks! I will try it.
minitreintje
12 Oct 2013 00:44 #39781 by cncbasher
note the tool table list required as in the gcode file T1 through to T6
( T01 | 3.302mm 0.1300in | 0.0000in | 0.0000in | 0 )
( T02 | 0.610mm 0.0240in | 0.0000in | 0.0000in | 0 )
( T03 | 0.813mm 0.0320in | 0.0000in | 0.0000in | 0 )
( T04 | 1.016mm 0.0400in | 0.0000in | 0.0000in | 0 )
( T05 | 1.118mm 0.0440in | 0.0000in | 0.0000in | 0 )
( T06 | 1.194mm 0.0470in | 0.0000in | 0.0000in | 0 )
Time to create page: 0.343 seconds
