<SOLVED> G1 Not working in program
12 Oct 2013 03:14 - 12 Oct 2013 23:24 #39785 by Jerre122
<SOLVED> G1 Not working in program was created by Jerre122
I have found the solution so this is solved.
It proved to be something simple (but it took quite a bit of looking to spot).
I had made a classicladder program to get a delay when reversing spindle direction. I had also altered the HAL signal "spindle-at-speed" for this, so the program wouldn't continue while the delay was still going.
But I made a fault in the classicladder program by connecting an output to the wrong classicladder hal pin, leaving "spindle-at-speed" forever false.
Original question:
Hello,
My machine is finally working in MDI. However, when trying to run a program the machine simply stops moving after the first few lines. There is no error at all.
Example of the first few lines of a program:
G17 G21 G40 G90
(Horizontal Roughing)
T1 M06
S2000 M3
G0 Z406
X382.04 Y-52.32 -->It moves to this point and then stops
G1 Z400.63 F1500.
Z400
X380.99 Y-52.01 Z399.81
X374.38 Y-49.09 Z398.53
I already tried everything I could think of like deleting the . after the F, changing the place of the F to the line above, adding some modal G code on the first line, but northing is working.
There are some example programs that aren't working either.
I really need a solution.
Last edit: 12 Oct 2013 23:24 by Jerre122.
12 Oct 2013 04:08 - 12 Oct 2013 05:54 #39787 by Jerre122
Replied by Jerre122 on topic G1 Not working in program
Ok I found out the reason, it turns out I cant use M3 for some reason. I can understand I can't use S2000 since I don't have an encoder, but not being able to use M3 seems weird. For some reason when M3 is included M6 becomes included in the active code list.
EDIT: I can't even turn the spindle on manually and then start the program.
EDIT2: I have found what went wrong.
Last edit: 12 Oct 2013 05:54 by Jerre122.
12 Oct 2013 07:50 #39790 by andypugh
Replied by andypugh on topic G1 Not working in program
This is very confusing. Can you start at the beginning, or is it all working now?
Using ladder for delays will work, and if you are comfortable with that then that is fine, but there may be other ways (possibly even built-in ways).
If you give us a more clear problem-description then we may be able to provide answers.
12 Oct 2013 23:21 #39800 by Jerre122
It is working now.
But I'm always interested to know about improvements.
Any idea about other ways for getting a delay when reversing spindle directions?
13 Oct 2013 01:29 #39803 by andypugh
Why do you need a delay? Knowing the problem you are trying to solve would make it easier to know what the best solution is.
The behaviour you want might well be something that you can program into the spindle drive.
Alternatively, if you just want a slow ramp down and up again, look at using a limit2 HAL component between motion.spindle-speed-out and whatever it drives. www.linuxcnc.org/docs/html/man/man9/limit2.9.html
If you are only using M3 and M4, and your spindle runs full speed in either direction, then you can probably do what you want with the "timedelay" HAL function: www.linuxcnc.org/docs/html/man/man9/timedelay.9.html
To avoid a delay when starting from stopped you probably need two timedelays and two XOR functions.
M3-out = M3-in XOR timedelay(M4-in)
M4-out = M4-in XOR timedelay(M3-in).
In HAL code that would look a bit like:
loadrt timedelay count=2
loadrt xor2 count=2
addf timedelay.0 servo-thread
addf timedelay.1 servo-thread
addf xor2.0 servo-thread
addf xor2.1 servo thread
# these are inhibits, so only do anything on the on-to-off transition
setp timedelay.0.on-delay 0
setp timedelay.0.off-delay 5
setp timedelay.1.on-delay 0
setp timedelay.1.off-delay 5
net m3-in motion.spindle.forward xor2.0.in0 timedelay.0.in
net m4-in motion.spindle.reverse xor2.1.in0 timedelay.1.in
net m3-delayed timedelay.0.out xor2.1.in1
net m4-delayed timedelay.1.out xor2.0.in1
net m3-out xor2.0.out  {parport.0.pin-01-out, or whatever}
net m4-out xor2.1.out  {parport.0.pin-02-out, or whatever}
Maybe ladder is actually simpler?
13 Oct 2013 17:51 #39810 by Jerre122
The reason I needed a delay is because the spindle needs time to stop. If you suddenly reverse the spindle the contactor wich activates the reverse spindle direction would activate before the contactor of the electric spindle brake. The brake wouldn't activate and the spindle would suddenly reverse (in a fraction of a second really) and the 3 V-belts going to the gearbox would slam against their case. I don't think this can be good for the spindle motor either.
Anyway I fixed this in ladder, but made a mistake leaving "spindle-at-speed" forever false. I didn't notice this while jogging or making G0 moves, only when running a program. Thats why it took a long time to find out that this was the problem.
It's solved now.
13 Oct 2013 18:35 #39811 by andypugh
It's actually probably OK, depending on a number of factors. If the only components involved are a 3-phase motor, the contactors and the incoming mains supply. This is "plug reversing" and it wasn't unusual to have motors deliberately wired to allow it in the days before electronic speed control. It is one way to stop you lathe faster, for example.
I spent some time using a surface grinder where the table traverse was controlled by a an electric motor that was plug-reversed by the trip cams on the table. That was doing 1second clockwise, plug-reverse, 1 second anticlockwise all day.
It's a nasty thing to do to an electronic speed control, but they can typically be set to ramp down and up again anyway, when they are reversed.
Depending on the number of reversals it might even be better in the long term than running a brake. If the motor can handle the reversal without overheating then it will not suffer any wear during the reversal, whereas brakes do wear fractionally with every operation. The belt slap sounds worthy of concern though.
13 Oct 2013 19:19 #39812 by cncbasher
Replied by cncbasher on topic G1 Not working in program
i'd go further and investigate the belts , chances are either one or more are slack , they should be changed as a set , not independantly .
if one's been changed then that one will be tight but the other will still be slack ..
As Andy says , most motors in this situation are designed to accept some reversal .
14 Oct 2013 00:48 #39813 by Jerre122
The brake is a electrical brake wich brakes on the motor itself so it doesn't wear out. It's a "Frenostat 2000" It was originaly on the machine so I decided to keep it for now.
I will see if I can tension the belts more but I think I rotated the motor as far as I could. (for tensioning the motor has a excentric mounting)
Otherwise I will just buy new belts.
Time to create page: 0.470 seconds
