Endless loops. Is it possible? [SOLVED]
31 Oct 2013 15:35 - 31 Oct 2013 21:07 #40439 by alberto-g
Endless loops. Is it possible? [SOLVED] was created by alberto-g
Hello, I would like to repeat a loop for an unlimited number of times.
My first try has been
o101 while [1]
o101 endwhile
but LinuxCNC hangs while loading this code.
Next try:
o103 repeat [10000]
0103 endrepeat
thinking I could get away with an almost infinite loop. But loading times are very high.
It seems like it is trying to scan the program until its end, which of course is never reached.
I'm new to CNCs in general, so please forgive me if I'm missing something obvious.
This is on a BeagleBone board, bb-lcnc.blogspot.co.at/p/machinekit_16.html.
Alberto
Last edit: 31 Oct 2013 21:07 by alberto-g.
31 Oct 2013 15:54 #40441 by Rick G
Replied by Rick G on topic Endless loops. Is it possible?
Yes, to prepare the plot, check to see if the gcode program is within the working envelope of the machine, check for errors, etc.
Perhaps explain what you are try to do so a different approach my be suggested.
Rick G
The following user(s) said Thank You: alberto-g
31 Oct 2013 16:03 #40442 by ArcEye
Replied by ArcEye on topic Endless loops. Is it possible?
Hi
Linuxcnc does not hang, it is Axis that never gets to the end of its code preview.
You can use a different front end which just displays actual movements or disable the preview
linuxcnc.org/docs/html/gui/axis.html#_axis_preview_control
31 Oct 2013 16:12 #40443 by alberto-g
Replied by alberto-g on topic Endless loops. Is it possible?
Thanks, I will try that.
I would like to use LinuxCNC like a sort of a PLC with a motion card.
I just need to wait for an input, execute some motions, then repeat.
Maybe some other project would be better suited for this task, like having a programming language with more features.
31 Oct 2013 17:57 #40446 by BigJohnT
Replied by BigJohnT on topic Endless loops. Is it possible?
LinuxCNC has a built in PLC check out the Classicladder section of the Integrators manual.
JT
31 Oct 2013 18:25 #40448 by alberto-g
ArcEye was right. (AXIS,stop) did the trick.
Now I'll read about the PLC part. It would be very powerful.
Thank you very much.
(written from the Beaglebone while LinuxCNC is running)
Time to create page: 0.187 seconds
