TTL trigger output
12 years 5 months ago #46779 by andypugh
Replied by andypugh on topic TTL trigger output
gillinderglass wrote: There is just one error. command - (EMC_TASK_PLAN_RESUME) cannot be executed until the machine is out of E-Stop and turned on.
Can you work round that? It sounds like the oneshot fires immediately, before the system is turned on.
If it is a problem, then take the output of the resume oneshot through an and2 component with something like amp-enable.
Time to create page: 1.407 seconds
