Tool Problem
25 Jan 2014 14:53 #43154 by Iken
Hello,
I would like to ask you for help. I have the some problem but I don't know how to solve it. PCB-Gcode generated drill file. When I open this file on the LinuxCNC 2.5.0 so there write me this error:
Near line 139 of ***drill.ngc:
Requested tool 4 not found in the tool table.
On the line 139 is:
M06 T04 (0.0400 )
My tool list is:
( Tool| Size | Min Sub | Max Sub | Count )
( T01 | 0.813mm 0.0320in | 0.0000in | 0.0000in | 0 )
( T02 | 0.900mm 0.0354in | 0.0000in | 0.0000in | 0 )
( T03 | 1.000mm 0.0394in | 0.0000in | 0.0000in | 0 )
( T04 | 1.016mm 0.0400in | 0.0000in | 0.0000in | 0 )
( T05 | 1.321mm 0.0520in | 0.0000in | 0.0000in | 0 )
Tool with number T04 is in the list.
When I rewrite T04 to T03, I have problem with tool number T05.
Do you know where is problem please?
25 Jan 2014 21:27 #43165 by newbynobi
Replied by newbynobi on topic [SOLVED] Requested tool not found in tooltable
The mentioned code is your tool list, but not the content of the tool file, depending of the GUI you are using, take a look in the tool table of linuxcnc.
Norbert
25 Jan 2014 22:52 #43167 by cmorley
When this next happens can you please post these two files found in your configuration folder. found in home/linuxcnc/configs/
something.tbl
something.var
Also what version of linuxcnc are you using,
what screen,
are you adding any patches.
Chris M
26 Jan 2014 17:18 #43204 by Iken
Thank you very much to your fast answers!
Problem was really in config file from LinuxCNC!
Time to create page: 0.317 seconds
