- Thank you received: 994
G96 CSS problem
- BigJohnT
12 years 7 months ago #45276
by BigJohnT
Replied by BigJohnT on topic G96 CSS problem
Here is the spindle section of my CHNC.
JT
#Spindle uses encoder.02 and pwmgen.02
#spindle scales
addf scale.0 servo-thread
addf scale.1 servo-thread
#10v/6000rpm=0.001667
setp scale.0.gain -0.0002
# offset for spindle
#setp scale.0.offset 0.0001loadrt pwmgen output_type=0 # This creates a 1Hz signal
setp scale.1.gain 60
#load abs comp make spindle RPM pos
loadrt abs count=3
addf abs.0 servo-thread
addf abs.1 servo-thread
addf abs.2 servo-thread
#spindle speed out limits
loadrt limit1 count=1
addf limit1.0 servo-thread
setp limit1.0.min -6000
setp limit1.0.max 6000
#set scale and pwm
setp hm2_5i20.0.encoder.02.scale -4096
setp hm2_[HOSTMOT2](BOARD).0.pwmgen.02.output-type 1
net spindle-speed-limit motion.spindle-speed-out => limit1.0.in
net spindle-speed-limit-out limit1.0.out => scale.0.in
net spindle-speed-DAC scale.0.out => hm2_5i20.0.pwmgen.02.value
net spindle-rpm => abs.1.in
net spindle-speed-abs <= abs.1.out
#spindle enable
net spindle-enable-req motion.spindle-on => and2.1.in0
net spindle-brake-sensor hm2_5i20.0.gpio.051.in_not => and2.1.in1
net spindle-enable and2.1.out => hm2_5i20.0.pwmgen.02.enable
# enable spindle drive
net spindle-enable => hm2_5i20.0.gpio.065.out
# force spindle lock pin out
net spindle-enable => hm2_5i20.0.gpio.042.out
# release spindle brake
net spindle-brake-prg not.0.out => or2.2.in0
net spindle-brake-logic motion.spindle-brake => not.0.in
net spindle-brake hm2_5i20.0.gpio.040.out <= or2.2.out
#spindle sync
net spindle-index motion.spindle-index-enable <= hm2_5i20.0.encoder.02.index-enable
net spindle-velocity motion.spindle-speed-in <= hm2_5i20.0.encoder.02.velocity
net spindle-revs motion.spindle-revs <= hm2_5i20.0.encoder.02.position
net spindle-velocity => abs.0.in
net spindle-v-abs abs.0.out => scale.1.in
net spindle-v-abs-out <= scale.1.out
# spindle speed
net spindle-velocity mult2.0.in0
setp mult2.0.in1 60
net spindle-abs abs.2.in mult2.0.out
net spindle-rpm abs.2.out
# spindle at speed
setp near.0.difference 0.1
net spindle-velocity near.0.in1
net com-spindle-vel near.0.in2 <= motion.spindle-speed-out-rps
net spindle-at-speed near.0.out <= motion.spindle-at-speed
# trick Axis
net trick-axis motion.spindle-reverse
#end of spindle
JT
- newbynobi
- Thank you received: 394
12 years 7 months ago #45281
by newbynobi
Replied by newbynobi on topic G96 CSS problem
Helo Jim,
if you do not use feedback, why do you use a PID? It is not necessary then.
This is a spindle.hal that works with PID and in both directions. (7i43 and 7i40 with DC motor and self made encoder)
wotks within 3 % accuracy! Encoder with 1000 ppr and max spindle speed 3500 rpm
you will need to adapt the PID values to your hardware
My INI has the following values:
# Spindle
[SPINDLE_9]
P = 4.0
I = 10.0
D = 0.0
FF0 = 1.0
FF1 = 0.8
FF2 = 0.0
BIAS = 0.0
DEADBAND = 5
OUTPUT_SCALE = 1.0
OUTPUT_OFFSET = 0.0
MAX_OUTPUT = 0.0
INPUT_SCALE = 1000.0
and for gmoccapy you need to connect than:
hope that helps.
Norbert
# SPINDLE S
# as I do use a 7i43 we will have to load the stuff for that
# you may need to add this to your needs
loadrt hostmot2
loadrt hm2_7i43 ioaddr=0xcc00 epp_wide=0 config="firmware=hm2/7i43/SVST4_4S.BIT num_encoders=2 num_pwmgens=2 num_stepgens=0"
setp hm2_7i43.0.pwmgen.pwm_frequency 100000
setp hm2_7i43.0.pwmgen.pdm_frequency 100000
setp hm2_7i43.0.watchdog.timeout_ns 10000000
addf hm2_7i43.0.read servo-thread
addf hm2_7i43.0.write servo-thread
addf hm2_7i43.0.pet_watchdog servo-thread
# for closed loop we ned a PID control, so lets load it
loadrt pid num_chan=1
addf pid.0.do-pid-calcs servo-thread
setp pid.0.Pgain [SPINDLE_9]P
setp pid.0.Igain [SPINDLE_9]I
setp pid.0.Dgain [SPINDLE_9]D
setp pid.0.bias [SPINDLE_9]BIAS
setp pid.0.FF0 [SPINDLE_9]FF0
setp pid.0.FF1 [SPINDLE_9]FF1
setp pid.0.FF2 [SPINDLE_9]FF2
setp pid.0.deadband [SPINDLE_9]DEADBAND
setp pid.0.maxoutput [SPINDLE_9]MAX_OUTPUT
# ---PWM Generator signals/setup---
# no quadratur counting = 1 else 0
setp hm2_7i43.0.pwmgen.01.output-type 1
# Set the spindle's top speed in RPM
setp hm2_7i43.0.pwmgen.01.scale 3500
setp hm2_7i43.0.encoder.01.counter-mode 1
setp hm2_7i43.0.encoder.01.filter 1
setp hm2_7i43.0.encoder.01.index-invert 0
setp hm2_7i43.0.encoder.01.index-mask 0
setp hm2_7i43.0.encoder.01.index-mask-invert 0
setp hm2_7i43.0.encoder.01.scale [SPINDLE_9]INPUT_SCALE
# we need a scale for feedback to the pid
loadrt scale names=scale_rps_to_rpm
addf scale_rps_to_rpm servo-thread
setp scale_rps_to_rpm.gain 60
net spindle-on hm2_7i43.0.pwmgen.01.enable <= pid.0.enable <= motion.spindle-on
net spindle-vel-cmd pid.0.command <= motion.spindle-speed-out
net spindle-output pid.0.output => hm2_7i43.0.pwmgen.01.value
net spindle-vel-fb-rps hm2_7i43.0.encoder.01.velocity => scale_rps_to_rpm.in
net spindle-vel-fb-rpm scale_rps_to_rpm.out => pid.0.feedback
net spindle-vel-fb-rpm motion.spindle-speed-in
net spindle-index-enable motion.spindle-index-enable <= hm2_7i43.0.encoder.01.index-enable
# spindle at speed detection #
loadrt near names=near_spindle_speed
addf near_spindle_speed servo-thread
# set the spindle speed inputs to agree if within 3%
setp near_spindle_speed.scale 1.03
# connect one input to the commanded spindle speed
# we declared above already
# net spindle-vel-cmd pid.0.command <= motion.spindle-speed-out
net spindle-vel-cmd near_spindle_speed.in1
# and the other input to the encoder-measured spindle speed
# net spindle-vel-fb-rpm scale_rps_to_rpm.out => pid.0.feedback
net spindle-vel-fb-rpm near_spindle_speed.in2
# connect the output to the spindle-at-speed input
net spindle-at-speed motion.spindle-at-speed <= near_spindle_speed.out
# Spindle
[SPINDLE_9]
P = 4.0
I = 10.0
D = 0.0
FF0 = 1.0
FF1 = 0.8
FF2 = 0.0
BIAS = 0.0
DEADBAND = 5
OUTPUT_SCALE = 1.0
OUTPUT_OFFSET = 0.0
MAX_OUTPUT = 0.0
loadrt abs names=abs_spindle_feedback
addf abs_spindle_feedback servo-thread
net spindle-vel-fb-rpm abs_spindle_feedback.in
net spindle-speed-rpm abs_spindle_feedback.out => gmoccapy.spindle_feedback_bar
net spindle-at-speed gmoccapy.spindle_at_speed_led
hope that helps.
Norbert
- jbunch
12 years 7 months ago #45286
by jbunch
Replied by jbunch on topic G96 CSS problem
JT,
I am using master. 2.6.0. It used to work with AXIS and 2.5.3 and it used to work with master. It now seems to have problems.
Jim
Jim
- BigJohnT
12 years 7 months ago - 12 years 7 months ago #45292
by BigJohnT
Did you change "anything" between 2.5.3 and master?
The basic G96 test in sim/lathe works fine.
JT
JT
Last edit: 12 years 7 months ago by BigJohnT.
- ap machine works
12 years 5 months ago - 12 years 5 months ago #46783
by ap machine works
Replied by ap machine works on topic G96 CSS problem
I'm having a similar issue, how was this resolved?
Last edit: 12 years 5 months ago by BigJohnT.
- newbynobi
12 years 5 months ago #46790
by newbynobi
You will need to explain your issue in detail, otherwise the answer will be,
Use a similar solution:-)
Norbert
Norbert
Time to create page: 0.268 seconds
