E Word with no G76
- lenarlwong
12 years 7 months ago #45350
by lenarlwong
Replied by lenarlwong on topic E Word with no G76
If I use the printer settings as a Reprap, all of the extruder moves show up as E. If I choose Mach3/EMC, all extruder moves show up as A. But if I add a Z lift, for some reason, E starts to show up again, I think only for the lifts. Here is my config file.
- ArcEye
- Thank you received: 240
12 years 7 months ago #45366
by ArcEye
Replied by ArcEye on topic E Word with no G76
Hi
Your ini file has the line
You might want to try changing that.
I cannot replicate your problem, with the stl file I am using, even if I set Z axis to lift I don't get any E 'axis' moves.
If changing the E to A in the ini file does not work, the best solution I have at present is
sed '/E/d' input.ngc > output.ngc
That will remove any line containing an uppercase E
(Just make sure you do not use one in any comments, or that line will be deleted too)
extrusion_axis = E
Time to create page: 1.097 seconds
