- Thank you received: 994
Need help with dxf2gcode [solved]
- BigJohnT
12 years 3 months ago #48725
by BigJohnT
Replied by BigJohnT on topic Need help with dxf2gcode
Python is not a compiled language so re-booting is not needed. I assume the directory where you put the .py file is not the same one that you issued the command in so nothing happened. The directions on the wiki say to put the files where ever you want. Your using 12.04 so I can offer no more help on trying to run the .py file other than you have to be in the same directory when you do ./filename.py in a terminal.
JT
JT
- Lc1975
12 years 3 months ago - 12 years 3 months ago #48727
by Lc1975
Replied by Lc1975 on topic Need help with dxf2gcode
In the terminal i go to the folder where the is the dxf2gcode..
Go to folder "source" then execute the command..
Terminal:
This is correct right?
After the command appears the error..
Terminal:
filipe@Vaio-VPCEH3K1E:~/Transferências/source$ ls
config
d2gexceptions.py
dxf2gcode.py
DxfImport
i18n
make_exe.py
PostPro
Core
d2gexceptions.pyc
dxf2gcode_pyQt4_ui
Gui
images
make
_pylupdate4_dxf2gcode.py
postpro_config
filipe@Vaio-VPCEH3K1E:~/Transferências/source$ ./dxf2gcode.py
Last edit: 12 years 3 months ago by Lc1975.
- BigJohnT
12 years 3 months ago #48728
by BigJohnT
Yes, that is correct and from the highlighting the file looks to be executable.
What happened after this command?
JT
JT
- Lc1975
12 years 3 months ago #48729
by Lc1975
This:
(PyQt4.QtCore.QString(u'dxf2gcode_pt_PT'), './i18n')
File "./dxf2gcode.py", line 980, in <module>
window = Main(app)
File "./dxf2gcode.py", line 89, in __init__
self.MyPostProcessor = MyPostProcessor()
File "/home/filipe/Transferências/source/PostPro/PostProcessor.py", line 100, in __init__
self.get_output_vars()
File "/home/filipe/Transferências/source/PostPro/PostProcessor.py", line 123, in get_output_vars
PostProConfig.load_config()
File "/home/filipe/Transferências/source/PostPro/PostProcessorConfig.py", line 187, in load_config
logger.debug(self.tr("read existing varspace '%s'") % (self.filename))
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 21: ordinal not in range(128)
- BigJohnT
12 years 3 months ago #48730
by BigJohnT
What version of Python is installed on 12.04?
10.04 has 2.6.5 and I have dxf2gcode_b02.py and it runs for me.
It's possible your download got trashed...
JT
john@zotac:~$ python
Python 2.6.5 (r265:79063, Feb 27 2014, 19:44:14)
[GCC 4.4.3] on linux2
Type "help", "copyright", "credits" or "license" for more information.
JT
The following user(s) said Thank You: Lc1975
- Lc1975
12 years 3 months ago - 12 years 3 months ago #48731
by Lc1975
Thanks to all
Solved my problem...
filipe@Vaio-VPCEH3K1E: python
Python 2.7.3 (default, Feb 27 2014, 20:00:17)
[GCC 4.6.3] on linux2
Then i use the version you tell..
Now works like a charm...
Time to create page: 5.563 seconds
