Pause in drilling cycle
12 years 2 months ago #50037 by ZeroLab
Pause in drilling cycle was created by ZeroLab
Hi community!
I have difficulties adding a 2 sec dwell during the following cycle
N108 G43 H1 Z10. N110 G98 G83 Z-6. R1. Q.3 F20.
My problem is that the brushless driver of BLDC moving the spindle has an overcurrent protection that inhibits further overcharges once the motor has been in that condition for more than 2 sec. So i can avoid it symply adding a 2 sec dwell between the drills.
Is there a way to do it? Am I using wrong Cycles? (I like this cycle because it gives complete clearence at each retract allowing proper chip breaking when working alluminiun)
Any suggestion could be a good help.
Thank you!
12 years 2 months ago #50061 by BigJohnT
Replied by BigJohnT on topic Pause in drilling cycle
If your using 2.6.x you can remap G83 to suit your needs.
linuxcnc.org/docs/html/remap/structure.html
JT
Time to create page: 0.859 seconds
