- Thank you received: 4
M66 problem - doesn't work without Q parameter
- nebelnoir
11 years 9 months ago #55444
by nebelnoir
M66 problem - doesn't work without Q parameter was created by nebelnoir
- Thank you received: 5334
11 years 9 months ago #55445
Replied by PCW on topic M66 problem - doesn't work without Q parameter
why not just set Q3600 or so...
- nebelnoir
11 years 9 months ago #55446
by nebelnoir
Replied by nebelnoir on topic M66 problem - doesn't work without Q parameter
or
(user code)
M66 P0 L3 Q3600
M66 P0 L3 Q3600
M66 P0 L3 Q3600
(user code)
Ok. Вut what if this is a technical equipment in the production line, which can only work once a day?
Or (more generally) I need different branches of Gcode, depending on the input signals.
How can I use digital input as a parameter in O codes? (I've tried to use motion.digital-in-00 (pin) or din-00 (signal) as parameter but it doesn't work)
(user code)
M66 P0 L3 Q3600
M66 P0 L3 Q3600
M66 P0 L3 Q3600
(user code)
11 years 9 months ago #55448
If you need to branch then read immediate and then run conditional code
if you want to wait just use a long q value (Q31557600 will wait a year)
The following user(s) said Thank You: nebelnoir
- nebelnoir
11 years 9 months ago - 11 years 9 months ago #55449
by nebelnoir
g21 g90
g0 x0 y0 z0
g4 p3
g0 x100
M66 P1 L0 Q100
o100 if [#5399 EQ 0]
g0 X0
o100 endif
o110 if [#5399 EQ 1]
g0 z50
o110 endif
g0 y100
g4 p3
g0 x0 y0 z0
m2
Thank you!
(L- - Mode 0: IMMEDIATE - no waiting, returns immediately. The current value of the input is stored in parameter #5399
linuxcnc.org/docs/html/gcode/m-code.html#sec:M66-Input-Control )
:laugh: , ok it's work. SOLVEDPCW wrote: (Q31557600 will wait a year)
ok it's work too. SOLVEDPCW wrote: read immediate and then run conditional code
g21 g90
g0 x0 y0 z0
g4 p3
g0 x100
M66 P1 L0 Q100
g0 X0
o100 endif
g0 z50
o110 endif
g0 y100
g4 p3
g0 x0 y0 z0
m2
Thank you!
Last edit: 11 years 9 months ago by nebelnoir.
Time to create page: 0.487 seconds
