- Thank you received: 240
x axes continuos
- ArcEye
11 years 8 months ago #56240
by ArcEye
Replied by ArcEye on topic x axes continuos
What I would do is have 2 gcode files.
verify.ngc just runs the code to print once and moves to the next position
This will not take long to load and you can check that the print and the offset distance are correct.
Then you can run fullrun.ngc, which is just a huge number of repeats of the code in verify.ngc, and have some confidence that the code will run properly
- albova
11 years 8 months ago #56241
by albova
Replied by albova on topic x axes continuos
the solution with two files I wanted to leave for the last but I think it will be one I will use.
Time to create page: 0.119 seconds
