image to g-code problem
11 years 8 months ago - 11 years 8 months ago #56365 by grey1beard
image to g-code problem was created by grey1beard
Just trying a quick experiment to see if a relatively simple method of producing the shape I want would work using the 'image to g-code' conversion.
however, it threw up the error shown in the screen grab attached. The thumbnail above the error window is the .jpg in question, and is designed to produce a dome with 24 ribs outside.
Any ideas as to getting this to work would be gratefully received.
Last edit: 11 years 8 months ago by grey1beard. Reason: spelling
11 years 8 months ago #56366 by grey1beard
Replied by grey1beard on topic image to g-code problem
Perhaps the first question should have been "where do I find the ini file to see if the Filter has the required lines inserted or not.
I thought I had done this successfully before, but so long ago I've forgotten the details !
11 years 8 months ago #56368 by dgarrett
Replied by dgarrett on topic image to g-code problem
you probably need to
sudo apt-get install libtk-img
11 years 8 months ago #56369 by BigJohnT
Replied by BigJohnT on topic image to g-code problem
grey1beard wrote: Perhaps the first question should have been "where do I find the ini file to see if the Filter has the required lines inserted or not.
Configuration files will be in /linuxcnc/config/name of your config
JT
11 years 7 months ago #56375 by grey1beard
Hi dgarrett.
Did that, but no change, still the same error window.
Hi John,
Thanks, so I went there and found the [FILTER] entry as per the manual, so I went back to the actual error window and tried to understand its meaning.
I assume that a "module" is an entry that should be present, but where ?
Should it be in the .ini file, as above, or in .../git/linuxcnc/bin image-to-gcode file ?
11 years 7 months ago #56376 by grey1beard
Just checked the image-to-gcode file and have copied the portion referred to here
def ui(im, nim, im_name):
import Tkinter
import ImageTk
import pickle
import nf
app = Tkinter.Tk()
rs274.options.install(app)
app.tk.call("source", os.path.join(BASE, "share", "axis", "tcl", "combobox.tcl"))
Hope that helps !
Time to create page: 4.765 seconds
