- Thank you received: 240
G38.2 randomly stops
- ArcEye
1) The screen ... Not sure if I am following you. Are you saying the screen goes over the electronics in the drawer and the screen gets grounded?
There are cables with either braided tinned copper wire or foil as the outer covering bar one.
If this outer screening is grounded it will protect the signal in the inner core(s)
If your components are grounded within a metal enclosure, that will also assist with screening.
Often all the components are mounted on an aluminium back plane or plate for that reason.
Just need to make sure that any clean independent power sources used, on the input side of the optos on the BOB for example, is not grounded to the
main power supply ground.
- JoeHildreth
- Thank you received: 12
andypugh wrote:
JoeHildreth wrote: 2) Do you or others have recommendations to make my wire job better?
It's nice and neat, at least.
I like to use ferrules into cage-clamps when using stranded wire:
www.rapidonline.com/cables-connectors/rv...-pack-of-100-33-1280
Great suggestion. Andy. I will order some of these and the crimper for my rewire.
One other thing, I think The thread should be moved maybe to a wiring forum. I didn't notice one when looking through the list of forum topics. Maybe it would be a good idea to create one. Thanks for the tip.
Joe
- JoeHildreth
OK, That cleared it up for me. Thanks!
My controllers and PSU's are fastened to the metal enclosure I made for my electronics drawer. I will take the ground from the AC line and bring it to the case and will do this for the 36VDC PSU's. Also, would it be wise to run an additional ground wire from the Ground on my controllers to the case, or will the supply be enough.
My 5VDC supply currently supplies the BOB. I was going to use this supply to run two small 5vdc cooling fans and supply input logic voltages. Are you saying this supply should should not share a ground with the other equipment? (Because I plan to use it to supply signal voltage to the BOB input pins?
I have some shielded wire like you have shown me. It has 4 22AWG wires and a metal braid. I will use this wire from my drivers to the 4 pin MIC connectors on the back. I should ground the metal braid to the case in my controller box, correct? Not the 2 pairs that are in this wire are not twisted pairs, does that matter, or should I be looking for a different kind of wire? I plan on these connections to run from the controller to the MIC plugs away from the signal lines. On the output side of the MIC jacks, the motors are connected using (2) 22AWG Twisted pairs. Should I replace this with the shielded cable as well? My controllers are running at 3A, according to the AWG chart I should be good with 22AWG wire, but would there be any benefit to bumping it up to 20AWG or 18AWG?
My signal lines ... I thing I will change the wire I am using with some CAT 5 twisted pairs. Would putting a small ferrite bead on each end of the wire be beneficial?
I will take Andy's advice and terminate the wire ends with ferrules on the braided wire.
In reference to the SSR. I looked around a bit looking for something that was 24-36VDC input and would drive TTL Voltages on the output. I am not really finding anything like that. I do however, have a couple dozen or so 24VDC mechanical relays I salvaged from an old Nurse call system. Could I use these for my probe and limit switches and the contacts for the TTL voltages? Would they inject noise or anything that I need to avoid. I have some space in my drawer that I can keep them a couple inches or so away from the BOB.
I appreciate the patience you and Andy have extended to me. As I get my ducks in order, I will pass this information along to the community. (Although, I think a wiring forum added here would be a great addition.)
Regards,
Joe Hildreth
- ArcEye
Some BOBs have the provision for each side of the opto isolators to be powered seperately, normally the input side is the side that takes the isolated power supply.
I was just pointing out that sharing a ground with an isolated supply kind of defeats the object.
I think the cases are usually grounded anyway for safety reasons, soon find out with a continuity tester.
There are different schools of thought.
I tend to ground everything on the AC side seperately from the DC side and have the transformer as an isolating component, since there is no physical contact between the two sides, just induction.
I think this is why you will sometimes see aluminium back planes inside machines on insulated stand-offs. All the DC components are grounded to it and the machine itself is grounded to AC earth for safety.
But I am not any sort of wiring guru :laugh:
Before I used a SSR, I used little 12v PCB relays quite happily. The only noise you might get is on contacts making or breaking and that should be when you are getting or losing a signal anyway.
I certainly had no trouble on the limits, which were on a permanently activated line through the switches to the relay coil and broke the contacts if one of the switches did.
- JoeHildreth
Some BOBs have the provision for each side of the opto isolators to be powered separately, normally the input side is the side that takes the isolated power supply.
My BOB is driven with buffers rather than opto-isolators. The 5V PSU supplies the power to the buffers and the rest of the card. So this sound like I should keep a separate ground for this PSU.
I tend to ground everything on the AC side separately from the DC side and have the transformer as an isolating component, since there is no physical contact between the two sides, just induction.
Isn't the AC ground usually connected to the case of a PSU? In this instance the AC ground is already tied to the metal of my drawer. I will take a meter and double check. So it sounds like I would benefit from a raised ground plane.
So if I understand all the conversation we have had, the following will be my plan of attack when rewiring my electronics enclosure. Please indicate if I have missed something.
1) Attach a raised isolated plane from the drawer to physically mount the drivers to.
2) Attach the ground of both 36V PSU to this ground plane
3) Use four strand shielded cable from the motor outputs to the 4 pin MIC connectors at the back of the drawer.
4) Ground the shielding of the motor cables to this ground plane.
5) Use twisted pairs with ferrous beads on each end to supply power to the drivers.
6) Install a ground bus bar or sorts for the 5v PSU and use this ground point for all my TTL signal grounds.
7) Use twisted pairs for all 5V power feeds with ferrous beads on each end.
9) Tie all AC grounds together.
Thank you ArcEye, you have helped me more than you know. I will do a write up of all as I do the wiring. When I am finished, perhaps you and others can give it a go over for correctness, and then post it for the rest of the community to use.
Regards,
Joe
- ArcEye
As you say the case is probably grounded to AC earth anyway.
I have seen it done and done it both ways, I tend to isolate AC from DC, but that does not mean it is the correct or the only right thing to do.
It will be quite difficult to achieve in a control box, because the metal of the sockets etc is usually the ground and in contact with the chassis anyway,
unless they go through a non conductive plate.
I would not go to any extra expense or trouble to follow my quirks!
Unless you get any problems, a common ground for all non-isolated supplies is probably fine and much easier to achieve.
