G38.2 randomly stops
- JoeHildreth
- Thank you received: 12
05 May 2015 01:35 #58383
by JoeHildreth
Replied by JoeHildreth on topic G38.2 randomly stops
Andy,
That is still a pretty neat wiring job!
I plan to run from the controllers to the MIC connectors in my panel too. Also, the piece of metal that all my MIC jacks are run in, I think I will use either a piece of fiberglass or plastic to insulate the jacks from the metal drawer since my AC ground will be attached via the PSU cases. I am thinking I will take an aluminum plate isolated from the drawer with standoffs and mount my controllers to them. If I turn them 180 degrees, I can run the motor wires on the outside and the signal wires to the inside of the drawer.
Thanks for pointing out the ferrules. They will make a neat job of it and reduce the risk of a stray wire strand from being naughty.
As a side note, My motor wires from the MIC jacks to the motors are 2 sets of 22 AWG twisted pairs. They are open to the air. Should I replace these with shielded wire? I mean, I will have signal wires routed along side them eventually in the cable management, or do you think the twists will keep it under control?
Joe
Joe
Time to create page: 0.073 seconds
