G-code error
11 years 3 months ago #61070 by allenwg2005
G-code error was created by allenwg2005
Hey folks!
Got a question.
Below are two gcode files of a .500 diameter circle, one with a lead-in and one without.
Neither file will load into LCNC.
Error= "Rijk words all missing for arc"
What's the fix for this?
Try and stay cool out there.
Thanks in advance for your help.
11 years 3 months ago #61075 by Todd Zuercher
Replied by Todd Zuercher on topic G-code error
Your first G2 line only has an I term, then you have a lot of G2 lines without any I or J. I think the I and J need to be specified on every G2 line even if they are 0 or unchanged from the last line.
The following user(s) said Thank You: allenwg2005
11 years 3 months ago - 11 years 3 months ago #61076 by Todd Zuercher
This might work better, you also had a bunch of problems with cutter comp and your lead-in size(s). You might also need to add a lead out.
N1G54G17G20G40G80G90G99 N2G0X0Y0Z1. N3T1M06 N4(*** T1 *** .250 Carbide Endmill ***) N5G00X-.25Y0S5200M03 N6G43Z1.H1T1 N7Z.13 N8G1Z0F208.M08 N9G42X0Y0Z-.03F733.4 N9G1X0.125Y0Z-.03F733.4 N10G2X.125Y0I-.125 N11G1X.125Y0 N12Z-.06F208. N13X.125Y0F733.4 N14G2X.125Y0I-.125 N15G1X.125Y0 N16Z-.09F208. N17X.125Y0F733.4 N18G2X.125Y0I-.125 N19G1X.125Y0 N20Z-.12F208. N21X.125Y0F733.4 N22G2X.125Y0I-.125 N23G1X.125Y0 N24Z-.15F208. N25X.125Y0F733.4 N26G2X.125Y0I-.125 N27G1X.125Y0 N28Z-.18F208. N29X.125Y0F733.4 N30G2X.125Y0I-.125 N31G1X.125Y0 N32Z-.21F208. N33X.125Y0F733.4 N34G2X.125Y0I-.125 N35G1X.125Y0 N36Z-.24F208. N37X.125Y0F733.4 N38G2X.125Y0I-.125 N39G1X.125Y0 N40Z-.27F208. N41X.125Y0F733.4 N42G2X.125Y0I-.125 N43G1X.125Y0 N44Z-.3F208. N45X.125Y0F733.4 N46G2X.125Y0I-.125 N47G1X.125Y0 N48Z-.33F208. N49X.125Y0F733.4 N50G2X.125Y0I-.125 N51G1X.125Y0 N52Z-.36F208. N53X.125Y0F733.4 N54G2X.125Y0I-.125 N55G1X.125Y0 N56Z-.39F208. N57X.125Y0F733.4 N58G2X.125Y0I-.125 N59G1X.125Y0 N60Z-.42F208. N61X.125Y0F733.4 N62G2X.125Y0I-.125 N63G1X.125Y0 N64Z-.45F208. N65X.125Y0F733.4 N66G2X.125Y0I-.125 N67G1X.125Y0 N68Z-.48F208. N69X.125Y0F733.4 N70G2X.125Y0I-.125 N71G1X.125Y0 N72Z-.5F208. N73X.125Y0F733.4 N74G2X.125Y0I-.125 N75G1G40X.125Y0 N76G0Z1.M09 N77G00G49Z5.M05 N78G90X0Y0 N79T1M06 N80M30
Last edit: 11 years 3 months ago by Todd Zuercher.
11 years 2 months ago #61101 by allenwg2005
Replied by allenwg2005 on topic G-code error
Thanks Todd,
I didn't realize LCNC didn't recognize comp insertion with a zero move, most NC machines do.
The lead-in was just me trying dramatic things to see if it would help.
Thanks again, Allen
11 years 2 months ago #61104 by BigJohnT
Replied by BigJohnT on topic G-code error
allenwg2005 wrote: Thanks Todd,
Thanks again, Allen
In order to arrive at the compensated position from the uncompensated position you need to move longer than the tool diameter. I can't imagine how a NC machine can do that without moving and still be in position at all times.
www.linuxcnc.org/docs/2.7/html/gcode/too...:cutter-compensation
JT
11 years 2 months ago #61107 by allenwg2005
JT,
Thanks for the reply.
According to other CNC forums, a 0 comp isn't an issue with most machine controls, it's been asserted that this is a LinuxCNC "thing".
I'm no authority on any of this, it's just what I've been told.
Not that it's any big deal, any software will have it's proclivities.
Time to create page: 1.450 seconds
