- Thank you received: 11
G76 - Pause in Z during exit taper Linux CNC 2.7.0
- verticalperformance
11 years 1 month ago #63085
by verticalperformance
Replied by verticalperformance on topic G76 - Pause in Z during exit taper Linux CNC 2.7.0
Went straight from 2.6.9 to 2.7.0 (not pre)
The config attached is a sim config. Should run without gardware. I run it in a virtual session using vmware player. I was quite suprised to see same blip on the physical machine and the virtual machine too. I'll have a ho with sim axis tonight.
Thanks for all the help with this.
- skunkworks
- Thank you received: 153
11 years 1 month ago #63087
by skunkworks
Replied by skunkworks on topic G76 - Pause in Z during exit taper Linux CNC 2.7.0
Jeff has been goofing around with it. Could you see if setting F0 before the g33/g76 fixes the problem?
Sam
Sam
11 years 1 month ago #63105
I'll have a go when I get home, assuming I can sneak out to the shed
. F0 interesting thought. The test code fragment nowhere sets the feed rate using an F code, but the full version does for the prior operations. That might explain why running the test code after the full version still hiccups - the last F code is still active. Not sure why running the test code again works though.
Might also try without the G96 - I'll just set a constant spindle RPM and see if any difference.
Did you observe the flip to G17 during running of the test code BTW - or is that just me too
As always, thanks.
Keith
As always, thanks.
Keith
11 years 1 month ago #63125
Genius!
If I set F0 prior to G76, I just get that tiny glitch you can see in the test code, but the velocity dropping to zero goes away.
If I run the code again and set say an F100 before the G76, the pause where zvel drops to zero reappears.
I can see the same effect in the HAL-SIM-LATHE sample config - so problem identified, and temporary work around found.
Now somebody needs to dig into the code and see why it would need an F0 before invoking G76 (and I suspect the fix will be invoke a F0 internally as part of the G76 internals!)
Anybody else using G76 on 2.7.0 put an F0 in just to be sure!
Thanks a lot guys, most appreciated.
- skunkworks
11 years 1 month ago #63142
by skunkworks
The following user(s) said Thank You: verticalperformance
- rellenberg
- Thank you received: 10
10 years 11 months ago #65302
by rellenberg
Replied by rellenberg on topic G76 - Pause in Z during exit taper Linux CNC 2.7.0
I compiled 2.7.2 with the TP debug output on, and ran a stripped-down version of the example program. I see the velocity blip too running the axis sim config. It's due a bug in how the TP calculates desired velocity for an arc blend. It always uses the requested feed in distance / time, rather than distance / rev (which is what actually controls feed in synced motions). I have a hotfix ready to test in the
hotfix/bug438
branch on my github page. All it does is skip arc blends for any spindle-synced motion, which will fall back to 2.6.x behavior.
Time to create page: 2.549 seconds
