Use of STEP-NC with LinuxCNC
10 years 11 months ago - 10 years 11 months ago #64643
I hadn't noticed before, but look in the configs...
sim->axis->canterp
Replied by andypugh on topic Use of STEP-NC with LinuxCNC
ArcEye wrote: So looks like in theory you could fairly easily substitute one parser / interpreter for another.
sim->axis->canterp
Last edit: 10 years 11 months ago by andypugh.
- ArcEye
- Thank you received: 240
10 years 11 months ago #64672
by ArcEye
Replied by ArcEye on topic Use of STEP-NC with LinuxCNC
I had never noticed that either, receives no explanation in the README.
It loads but errors and you cannot load a file, errors on line 0 trying to read it.
The framework is there in the file tree src/emc/canterp/ complete with Submakefile
You just need to make it work first before trying to substitute for another interpreter
Machine configuration directory is '/usr/src/linuxcnc-dev/configs/sim/axis'
Machine configuration file is 'canterp.ini'
Starting LinuxCNC...
Found file:/usr/src/linuxcnc-dev/lib/hallib/core_sim.hal
Note: Using POSIX realtime
Found file:/usr/src/linuxcnc-dev/lib/hallib/axis_manualtoolchange.hal
Found file:/usr/src/linuxcnc-dev/lib/hallib/simulated_home.hal
interp_from_shlib(libcanterp.so)
interp_from_shlib() -> 0x9dd1a0
Canterp::on_abort reason=6 message=''Canterp::on_abort reason=6 message=''interp_from_shlib(libcanterp.so)
Canterp::on_abort reason=5 message=''Canterp::on_abort reason=5 message=''interp_from_shlib(libcanterp.so)
- ArcEye
10 years 11 months ago #64674
by ArcEye
10 years 11 months ago #64679
Not the best of signs, that it fails to parse its own example...
Does it work if N.... is edited to be N0001 (ie, an actual number)
ArcEye wrote: Also tried loading the file fragment from the header of the canterp.cc source
Shows it is reading it, even if it says it does not understand it.
- ArcEye
10 years 11 months ago #64691
by ArcEye
Time to create page: 0.161 seconds
