- Thank you received: 6
Need help in Incremental Round Move
- G0G53Z148
10 years 11 months ago #65699
by G0G53Z148
Replied by G0G53Z148 on topic Need help in Incremental Round Move
i think we discuss different things
Linuxcnc must use g2 for round
At work HH uses after linear move R and the arc will be roundet
linuxcnc must tolt G2 <where to travel> < Radius>
User must Calculate the start and endpoint
if move will be longer or shorter Radius must be recalulatet
when CAM is used there is the radius in clear
i like oldschool and have not cam to use
i think this explain what i mean
try it
download the trial and use then you understand what i mean
HAND
try it
HAND
10 years 11 months ago #65701
Replied by andypugh on topic Need help in Incremental Round Move
[quote="G0G53Z148" post=65699Linuxcnc must use g2 for round[/quote]
Or G3
If you only specify a radius, does the system always assume the short arc?
With only a start and end point and radius there are always two solutions, or none.
Or G3
linuxcnc must tolt G2 <where to travel> < Radius>D
- jepler
- Visitor
10 years 11 months ago #65704
by jepler
Replied by jepler on topic Need help in Incremental Round Move
It sounds like you're describing a fillet operation. You're right that LinuxCNC's gcode dialect does not support this.
- G0G53Z148
10 years 11 months ago #65711
by G0G53Z148
jepler ! you are right
english i snot ma native but you have checkt it thank you
@ andy i dont want spezifie an g2 or g3 move now it was the discuss abou arc rounding
example
linuxcnc
G91.1
G1 G41 Y0
G1 X9
G2 X10 Y-1 I0 J-1
G1 Y-9
G2 X9 Y-10 I-1 J0
G1 X-5
G40
other cnc Terivat
G1 G41 Y0
G1 X10 R1
G1 Y-10 R1
G1 X-5
i hop this is now clear for you what does i mean
Linuxcnc is a Goog controller but some thisgs are very very cumbersome :woohoo:
example
linuxcnc
G91.1
G1 G41 Y0
G1 X9
G2 X10 Y-1 I0 J-1
G1 Y-9
G2 X9 Y-10 I-1 J0
G1 X-5
G40
other cnc Terivat
G1 G41 Y0
G1 X10 R1
G1 Y-10 R1
G1 X-5
10 years 11 months ago #65712
You can add your own G-codes if you want:
linuxcnc.org/docs/2.7/html/remap/remap.html
Though you can't re-map G1, as far as I know. You would have to add a G1.1 (for example)
G0G53Z148 wrote: Linuxcnc is a Goog controller but some thisgs are very very cumbersome
- G0G53Z148
10 years 11 months ago - 10 years 11 months ago #65715
by G0G53Z148
because english is not my native language i must say
i have after a long time my machine running as good with linux
only one change will be made for future to mesa
more i dont want to do and remap
thanks
thanks
Last edit: 10 years 11 months ago by BigJohnT. Reason: videos off topic
Time to create page: 2.701 seconds
