O-Words to open files
- grewgood
12 Jun 2010 14:28 #3121
by grewgood
O-Words to open files was created by grewgood
My "GFile1.ngc" contains the following
o<GFile1>sub
G91
G0X30
o<GFile>endsub
M2
My "Test2.ngc" file contains
o<GFile1>CALL
M2
I load Test2.ngc without any problem (in axis) but when I try run, there is no action. No error, no message.
I have tried a few variations. Any suggestions?
Greg
Greg
o<GFile1>sub
G91
G0X30
o<GFile>endsub
M2
o<GFile1>CALL
M2
Greg
Greg
- ArcEye
- Thank you received: 240
12 Jun 2010 16:46 #3123
by ArcEye
Replied by ArcEye on topic Re:O-Words to open files
I refer you to this topic to which I previously posted
www.linuxcnc.org/component/option,com_ku...d,1672/lang,english/
As far as I could tell, calling named files does not work ( In 2.3 at least) but calling numbered files works fine.
Arc Eye
Arc Eye
- BigJohnT
- Thank you received: 994
13 Jun 2010 13:39 - 13 Jun 2010 13:50 #3128
by BigJohnT
Replied by BigJohnT on topic Re:O-Words to open files
Calling named files has worked since 2.3.
Greg, you can't have caps in the called file name.
Last edit: 13 Jun 2010 13:50 by BigJohnT.
14 Jun 2010 11:12 #3136
Replied by andypugh on topic Re:O-Words to open files
[/quote]
Indeed. The parser strips out all spaces and converts to lower case, so it is looking for the file "test2.ngc" and not finding it.
[/quote]
Time to create page: 0.087 seconds
