work with x,y and another axis not involved
- eddycnc
18 Jun 2010 05:12 #3168
by eddycnc
work with x,y and another axis not involved was created by eddycnc
Dear All,
I've a problem and i don't know very well EMC2..
I want to dispense a product on a surface..
I've used the DXF2Gcode utility to have the Gcode for x,y axes
My problem is...
If i want dispense uniformly a product over the x,y route using another axis how can i do?
Can i use axis interface?
My problem is...
- Rick G
- Thank you received: 114
19 Jun 2010 05:25 #3173
by Rick G
Replied by Rick G on topic Re:work with x,y and another axis not involved
Hello,
I do not think that will be a problem, I think if you do a search there are some threads on emc with glue dispenser and extruder. If you are dispensing a material at a constant rate could you use the spindle command to turn the dispenser on and off?
Sorry I do not know the exact links.
Rick G
Rick G
- eddycnc
27 Jun 2010 07:11 #3209
by eddycnc
Replied by eddycnc on topic Re:work with x,y and another axis not involved
yes i must use a spindle command to turn the dispenser on and off...
Time to create page: 1.050 seconds
