[Solved] "Bad character '-'" (and '+') in G-code. Program won't load.
9 years 10 months ago - 9 years 10 months ago #84370 by clunc
I'm posting this because, after 8 years of staring at G-code (as a hobbyist only), I am (a) 8 years older, and (b) capable of the most foolish of mistakes.
I'm accustomed to hand-editing programs spit out of my CAM software, to change constants over to variables, etc. This involves "doing a little typing," and I've done it so many times, it's old hat, and I don't even see it. (...and I don't even see it.)
So "all of a sudden!", even though "I never changed anything!" and "it had always worked before!", LinuxCNC threw a "Bad character '-'" error on one of the last lines a recent program I loaded. Just the one line. All the other '-'s in the code were fine; only in that one place did it hate the '-'. (I had been away from the machine for a couple of weeks.)
It happened to be one of those hand-edits I always add to park the cutter at the end of the code. I use absolute coords:
G53G90G0-Z0.5
Do you see it? Good for you! You are a professional! I stared and stared at it. It was only as I was typing up a problem report (something like Why is My Version of LinuxCNC Possessed?) that I finally saw it. (I had the whole screen cap and everything... sheesh).
G-code AIN'T algerber: there's No Such Thing as -Z (or -X or -Y) in G-code syntax.
Z-0.5.
Posted on the off-chance that someone else might search for "Bad character" here someday. I wish I had those four hours back... ;^)
Last edit: 9 years 10 months ago by clunc.
9 years 10 months ago #84383 by andypugh
clunc wrote: G-code AIN'T algerber:
Though it is quite close to Gerber ;-)
9 years 10 months ago #84393 by Todd Zuercher
I could see how that could be a frustratingly difficult typo to pick out at first.
9 years 10 months ago #84412 by clunc
In fact, at one point I even typed three lines of code to test, quite oblivious to where I was placing signs:
G53G90G0Z0.5
G53G90G0Z-0.5 # right
G53G90G0+Z0.5 # WRONG
only to conclude that thing which didn't like negatives had changed its mind and now didn't like +!
(Oh, must dash; the nice man is here with my sanity pills.)
9 years 10 months ago #84413 by clunc
@andypugh
lol
I had an "ah-ha!" revelation that, that must be the explanation for the 'G'! "Must be Gerber!"
Wikipedia doesn't actually out-and-out credit Gerber with it however, although it suggests that a Gerber file is a flavor (RS-274-D) of regular G-code (RS-274) and the wikipedia entry for "Gerber file" refers to RS-274-D as "Standard Gerber" format, but which is "obsolete" and "revoked."
In a separate article ( en.wikipedia.org/wiki/History_of_numerical_control ), G-code is identified as having first been used on GerberScientific plotters and was later adapted for CNC use.
However, a search for 'G-code' at www.gerberscientific.com (redirects to www.gerbertechnology.com ) returns:
"No results found for search term g-code."
(Now looking into the history of the troublesome minus sign... Is it, really, necessary...)
9 years 10 months ago #84414 by Todd Zuercher
And to venture further off topic, I work with some older Gerber Scientific CNC routers, and what they run natively isn't even close to G-code (it isn't even human readable code), although they can be configured to accept a rudimentary form of G-code.
(If we didn't have a huge library of work (many years of man hours) created using the old Gerber Software, these machines would probably be waiting in line for a Linuxcnc brain transplant.)
Time to create page: 1.551 seconds
