single stroke text engraving font
9 years 10 months ago #84962 by johns00056
single stroke text engraving font was created by johns00056
I am trying to engrave small text lettering 1/4" high with a 1/16" ball end mill. Is there a way to make it use one stroke , rather than moving around the perimeter of each part of the letter? (I want it like Haas default engraving)
I am using truetype tracer with ncgui on ubuntu 2.5.3
There are a bunch of different fonts that came with linuxcnc, but they all engrave the same way, by moving around the perimeter of each part and leaving an island in the center of each stroke.
9 years 10 months ago #84984 by cmorley
9 years 10 months ago #84994 by andypugh
Replied by andypugh on topic single stroke text engraving font
f-engrave is there as a package if you search Synaptic for LinuxCNC. (but I have never used it)
I wrote some G-code to engrave numbers (and only numbers) if that is what you need.
forum.linuxcnc.org/forum/20-g-code/27169...numbers-on-cylinders
9 years 10 months ago #85015 by johns00056
Replied by johns00056 on topic single stroke text engraving font
cmorley, Thanks for the help. The wiki link that you posted is slightly different than the current one and has more information.
---Also, if you see the font path highlighted in RED, you probably do not have a correct path to a .cxf font file. ---
This is what my machine is doing. I put the engrave-11.py file and the font .cfx file in both nc_files and mysubs , without success.
I believe that I have the permissions on the files set correctly.(read and write, execute as program)
I have tried a bunch of different search paths, in the engrave-11.py file -
version = '11'
#fontfile = "/usr/share/qcad/fonts/standard.cxf"
##fontfile = "/usr/share/qcad/fonts/romanc.cxf"
#fontfile = "fonts/standard.cxf"
#fontfile = "/home/johns/fonts/standard.cxf"
#fontfile = "/home/johns/linuxcnc/nc_files/standard.cxf" ####this results in second screenshot
fontfile = "/home/johns/linuxcnc/nc_files/mysubs" #### this gives first screenshot
##added 12/31/16 john s. for engraving
[FILTER]
#PROGRAM_EXTENSION = .png,.gif,.jpg Grayscale Depth Image
PROGRAM_EXTENSION = .py Python Script,.cfx ##### not sure if I need to have a description after the .cfx , like Python Script, or something?
#png = image-to-gcode
#gif = image-to-gcode
#jpg = image-to-gcode
py = python
cfx = ##### not sure if this line is right , or if I even need this .
SUBROUTINE_PATH =/home/johns/linuxcnc/nc_files/mysubs
USER_M_PATH = /home/johns/linuxcnc/nc_files/mysubs
#FONTFILE = /home/johns/linuxcnc/nc_files/mysubs/standard.cxf #### this line did mot help 12/31/16 john s.
# the below 2 lines are examples, a list of directories separated by a colon (no spaces)and are searched in order for first qualifying file#######
#SUBROUTINE_PATH = ../../../nc_files/ngcgui_lib:../../../nc_files/ngcgui_lib/utilitysubs
#USER_M_PATH = ../../../nc_files/ngcgui_lib/mfiles
andypugh, thanks for the input. I need letters and numbers. Synaptic looks pretty complicated ,for me.
9 years 9 months ago #85149 by johns00056
I found a program that will do what I want. StickFont from ncplot.com.
It is for Windows and it cost $25.00 with a free trial for 15 days.
It was easy to download and worked perfectly.
5 years 7 months ago - 5 years 7 months ago #202828 by IronBones
Replied by IronBones on topic single stroke text engraving font
I also was trying to install various fonts , engraving font but until then I discovered a platform that has very many font styles and many sizes. I am a freelancer by profession and often have orders for logo sketches from various companies or stores. Now with this platform, my work has become more efficient, increased my income, and therefore the number of clients has increased. For those who work in this field, I can recommend this platform upfonts.com/knockout-font-straight-outta...ton-font/upfonts.com . After that, it will be much more efficient and easier to work and create.
Last edit: 5 years 7 months ago by IronBones. Reason: mistake
Time to create page: 3.076 seconds
