g76 Question abuout clearance from material
9 years 7 months ago #90181 by hhandresen
I'm trying to do thread via g76, but after a cut, when the tool is going back to beginning, it's not far away from the material and therefore chrashing the thread.
I can't find the correct parameter to set the clearance
Anyone can help ?
(I'm doing 20mm thread and the tool go out to 20mm when returning to start.)
9 years 7 months ago #90207 by andypugh
Replied by andypugh on topic g76 Question abuout clearance from material
It is the "I" number. According to the docs:
linuxcnc.org/docs/2.7/html/gcode/g-code.html#gcode:g76
It should be a negative number for external threads.
9 years 7 months ago #90213 by hhandresen
Replied by hhandresen on topic g76 Question abuout clearance from material
NICE :) Thanks
9 years 4 months ago #95200 by massimodamassa
Replied by massimodamassa on topic g76 Question abuout clearance from material
I would like to share with the Italian friends, I hope to have posted in the right area
Time to create page: 0.361 seconds
