- Thank you received: 10
Gcode plasma
- beauxnez
i want to do a test of my cnc plasma, I put a limit to find the 0 of the tole.
I know how to do gcode with cambam but the problem with my plasma c is that I have to cut in contact with The tole then I go up 2 mm.
I have to do to generate the gcode?
- Thank you received: 7491
If it is to have the torch find the metal and go up 2mm, you have to do that in Gcode, inkscape can do that for each cut, i did not test NativeCam for that as i use a config that does everything automaticly.
- Thank you received: 4153
gnipsel.com/shop/plasma/plasma.xhtml
- beauxnez
tommylight wrote: Inkscape has gcodetools included that can do plasma CAM, NativeCam has plasma CAM.
You have a link because I have to search on google there is nothing that speaks of nativecam and inkscape?
- beauxnez
rodw wrote: Big John T has a touchoff.ngc file here that will show you how to do it.
I'm sorry but it's really not clear to me. 6 files I have to copy them into home /...../ linuxcnc / ?
forum.linuxcnc.org/40-subroutines-and-ng...-is-features-renamed
Open a terminal and type : sudo apt-get install inkscape
press Y and enter.
