Reading Hal pins from Gcode [SOLVED]
9 years 6 months ago - 9 years 6 months ago #92328 by rodw
I've been trying to workout how to read the value of hal pins from gcode so I can access values set in the GUI to set various cutting parameters. I'm using Master branch.
From a link to documentation Andy posted on an earlier thread I have changed my .ini file to include:
[RS274NGC] FEATURES = 8
I have a pin called
plasma.G0-Gap
So in Gcode on a metric machine in the MDI window, I have tried this
F 2000 g1 y #<_hal[plasma.G0-Gap]>
But I get this error
Named parameter #<_hal[plasma.g0-gap]> not defined
I have not found an example , but it appears to be correct syntax to me.
What am I doing wrong?
Is the upper case in the pin name significant?
A quick example of the correct syntax would be really appreciated.
Last edit: 9 years 6 months ago by rodw.
9 years 6 months ago - 9 years 6 months ago #92330 by tommylight
Replied by tommylight on topic Reading Hal pins from Gcode
Do not take my word for it, but
needs a parameter, namely a value of something like 2 or 3 in your case (mm).
Just a stab in the dark.
Also G0 on a pin? An Y in the mdi line with no actual position?
I know it should get that from the pin value, but Y??? Should it be Z?
Oh well, back to cleaning up the mess in the shop.
Last edit: 9 years 6 months ago by tommylight.
9 years 6 months ago - 9 years 6 months ago #92332 by rodw
Replied by rodw on topic Reading Hal pins from Gcode
Tommy, thanks
I tried adding a G21 to set metric before it but that did not work. Same error.
And yes, it will be Z once I get organised but currently that needs a negative value. I know thats easy, but keeping it nice and simple while testing.
I could net see any examples on parameters to G91.
I have to tell you I know nothing about Gcode
9 years 6 months ago - 9 years 6 months ago #92334 by rodw
Ooops sorry, I meant no examples for G1.
To me, it is clearly not finding the pin #<_hal[plasma.G0-Gap]>
as anything on the line after it does not generate an error.
9 years 6 months ago #92336 by rodw
Here is the GUI
The value I'm trying to read is the 45 above the Rapid Gap - button
9 years 6 months ago #92337 by rodw
Solved.The error is because there is upper case characters in the pin name becasue the interpreter converts everything to lower case.
I tried saving a pin with all lower case characters to parameter #33 with this command
#33 = #<_hal[thcad10.target-velocity]>
I did not get an error message and after I closed Linuxcnc, the parameter was saved in linuxcnc.var.
33 11288.476562
I then picked a random gmoccapy plasma pin that was all lower case and it also saved to #33 happily.
Very cool!.
This parameter is the target velocity (frequency) returned by the Mesa THCAD at the required preset torch volts.
For those interested, if you are saving values in your own custom parameters, if you create them in the linuxcnc.var file they become persistent and that are saved from one session to the other.
So now all I need to do is to rename a few pins and I'm in business!
PS. This is feature is very poorly documented
The following user(s) said Thank You: tommylight, AndrewL
Time to create page: 5.777 seconds
