Reading Hal pins from Gcode [SOLVED]
9 years 6 months ago #92348 by tommylight
Replied by tommylight on topic Reading Hal pins from Gcode
Again, there is no stopping you ! Good job.
9 years 6 months ago #92375 by Todd Zuercher
Replied by Todd Zuercher on topic Reading Hal pins from Gcode
Using the hal pin parameters might work. But I would not trust it for data entered and used during a run. Those parameters are not always updated during a run. A better approach would be to connect the hal pins to motion.analog-in-xx pins and read them in using G66.
9 years 6 months ago #92391 by rodw
Replied by rodw on topic Reading Hal pins from Gcode
Todd Zuercher wrote: Using the hal pin parameters might work. But I would not trust it for data entered and used during a run. Those parameters are not always updated during a run. A better approach would be to connect the hal pins to motion.analog-in-xx pins and read them in using G66.
Thanks Todd, I am aware of the limitations but to set the starting parameters, I think they'll be fine.
Time to create page: 3.357 seconds
