- Thank you received: 114
[solved] M66 P1 L4 Q24000 this command can make gcode iterruption?
- bkt
9 years 5 months ago #93073
by bkt
Replied by bkt on topic M66 P1 L4 Q24000 this command can make gcode iterruption?
the 7i77ISOL maybe arrive to my office next tuesday ... I can use it for 7i76 too or exist 7i76isol?
In these case I use a 7i77 card ... but I plan to add these isolator to all my machine So I ask you these new info.
Sorry I use these wrong channel to make an other request, because your answers are faster here than on other side.
You suggest me to use vertical terminal blocks on 7i77 ... your block is phoenix contact or other brand? ... this in order to find the right terminal. The phoenix seller suggested other types of terminal (my side, mesa side is ok). Best for my purpose .... but I'm sure the builder who does yours has similar solutions as well. Unfortunately I did not understand what brand they are. I would not like to find myself with any kind of coupling problems so I would prefer to use the same brand's clamps .... If I was too intrusive, please reply to my mail. (i send you a request for to have more hight terminal block for insert 7i77 into a box but with terminal outside the box trough a windows, you suggest my vertical terminals).
next week after instal isolxx renew these post with result.
giorgio
giorgio
- Thank you received: 5334
9 years 5 months ago #93086
Replied by PCW on topic M66 P1 L4 Q24000 this command can make gcode iterruption?
The 7I77Isol only works with the 7I77
Note the the 7I77 (and 7I76) field I/O is already isolated so this is very unlikely to make any difference
with your M66 issue
You can order top entry connectors from Mesa
with your M66 issue
- bkt
9 years 5 months ago - 9 years 5 months ago #93130
by bkt
Ok I understand ... no matter ... I will have more confidence not to create disconnections between 6i25 and 7i77 ... but yesterday on a machine I have in test i have a pin on a 7i77 that goes on and off every 1.3 Sec / 1.5 sec ... stay on 0.3 seconds than go off ... sometime the mesa pin does not see the on statement .... I control with halshow ... electrical level of ON is 24.3V electric level OFF = 0.2V ..... the signal comes out from a PLC .... and I also monitored that .... when the PIN mesa does not go away in ON state .... to make this happen again I have to take off the wire from the terminal and reconnect it again ... so everything resumes running.
this time the code is similar but I use L3 instead L4 ... but the problem is halshow result not Lx....
some ideas?
Top entry that you suggest me is less hight than I would. I need al lest no less than 30mm from board terminal. I find pre-cable terminal ...
Giorgio
some ideas?
Giorgio
Last edit: 9 years 5 months ago by bkt.
9 years 5 months ago #93138
If the 7I77 does not see a 24V input, something very basic is wrong,
If a 7i77 input hal pin (hm2_5i25.0.7i77.0.0.input-xx or hm2_5i25.0.7i77.0.0.input-xx-not)
does not match the input state that suggests that there may be a connector problem
(this can be checked by measuring the input voltage on the back of the 7I77 card)
Anothe rpossibility is that you have lost communication with the 7I77 card, Do you have sserial errors when
this occurs? is the sserial run flag still true?
What version of linuxCNC are you running? There were some sserial error handling fixes somewhere early on the 2.7
range
range
- bkt
9 years 5 months ago #93151
by bkt
not see sserial error .... but there is a specific pin for check these in halshow or when you talk about sserial erro you refer to user meSSAGES?
Lcnc 2.8 ja14 on these machine ... but I've suspect that the first machine have the same ... that machine is on ubuntu 14.04 Lcnc 2.8 JA current.
giorgio
giorgio
9 years 5 months ago #93169
If you dont have any sserial errors, it seems most likely you have a very
basic problem with the signal wiring maybe a lack of common ground between
systems.
I would suggest measuring the 7I77 field input that is giving you trouble from
the back of the 7I77 card (to eliminate connector problems)
Measure from the input pin to 7I77 TB2 pin 8
systems.
Time to create page: 3.745 seconds
