- Thank you received: 1480
Z axis oscillating motion for routing marble and granite
9 years 3 months ago - 9 years 3 months ago #95862
Replied by Todd Zuercher on topic Z axis oscillating motion for routing marble and granite
If you are having trouble with a step in the commanded output caused by where in the wave pattern the signal from the sigen is connected or disconnected from the position command. perhaps you may need to run it through a limit2 component as well.
linuxcnc.org/docs/html/man/man9/limit2.9.html
So the hal arrangement might look something like this.
joint-pos-cmd \
joint-pos-cmd \ > mux -> limit2 -> stepgen
sigen -> offset /
Last edit: 9 years 3 months ago by Todd Zuercher.
- Thank you received: 4153
9 years 3 months ago #95863
Replied by rodw on topic Z axis oscillating motion for routing marble and granite
You could consider writing your own hal component. This would let you save the current position in a static variable so it can be referenced on the next pass through the servo loop.There are some included in the external offset branch but look at some of the simpler examples to understand how this works.
compiles and installs a component
halcompile --install mycomponent.comp
- Yannis
9 years 2 months ago #97405
by Yannis
Replied by Yannis on topic Z axis oscillating motion for routing marble and granite
hi
the oscillation of the tool is something common in alphacam stone
check in the you tube for example videos
- danilom
- Thank you received: 5
9 years 2 months ago #97407
by danilom
Replied by danilom on topic Z axis oscillating motion for routing marble and granite
Yes I found it out eventually in Alphacam, so I gave up on doing it trough Linuxcnc .
Thanks Yannis
Thanks Yannis
- Yannis
9 years 2 months ago #97412
by Yannis
You are in stone business ?
- danilom
9 years 2 months ago #97428
by danilom
Not really, I was just retrofitting one Ravelli Teorema stone router, but I am glad if I can be of any help just ask
Time to create page: 0.349 seconds
