Changing Z-Height While Maintaining Y Velocity
9 years 2 months ago #97185 by PlasmaRemoval
Changing Z-Height While Maintaining Y Velocity was created by PlasmaRemoval
I would like to perform multiple moves in the Z axis while maintaining a constant velocity along the Y axis. For example, I would like to be able to execute something similar to:
G1 X1 Y1 Z1
G1 Y3 Z1
G1 Y5 Z2
...without decelerating and then accelerating again in the Y direction.
Is this possible? I am using a Shopbot PRSalpha Buddy with a Mesa 7i76 board and LinuxCNC. I have tried using G64, but still get more acceleration along Y than I would like.
Thanks!
9 years 2 months ago #97192 by andypugh
Replied by andypugh on topic Changing Z-Height While Maintaining Y Velocity
Is the application plasma torch height adjustment?
9 years 2 months ago #97196 by PlasmaRemoval
Replied by PlasmaRemoval on topic Changing Z-Height While Maintaining Y Velocity
Yes, although it's a nonstandard torch for which the typical voltage-based adjustments will not work. We plan to probe the surface to measure height changes.
9 years 2 months ago #97199 by andypugh
In that case, you could investigate "probekins"
wiki.linuxcnc.org/cgi-bin/wiki.pl?ProbeKins
Your problem sounds identical.
The following user(s) said Thank You: PlasmaRemoval
9 years 2 months ago #97200 by PlasmaRemoval
That module does sound interesting. Do you know where I can find the original source code? The Gitweb link in the wiki is dead. I found an old compiled version on the forum, but I would prefer the source if possible.
Is there no simple G code means to avoid acceleration along one axis between commands affecting a different axis? The module seems like overkill for handling this, but maybe there is no simple solution.
Thanks!
9 years 2 months ago #97201 by andypugh
The advantage of that module is that it doesn't require special G-code, any 2D plasma CAM software will work.
As for the second question, I don't know. I have never needed to worry about the trajectory planner with my slow old machines
Time to create page: 4.160 seconds
