Unable to cut correct thread with G76
9 years 1 week ago #100538 by bjames28
Replied by bjames28 on topic Unable to cut correct thread with G76
Many thanks for the replies.
After days of investigation the problem was found in the timing belt drive setup used between the spindle and encoder:
The pulleys were not exactly the same size, despite original statement of shop owner. After matching the size of pulleys the thread cuts are PERFECT. We could go even for 1200 RPM without quality loss. So the G76 and G33 work very well, thank you again for the great software and hardware (Mesa 7i90).
8 years 10 months ago #103189 by cadcam
Replied by cadcam on topic Unable to cut correct thread with G76
Patrick T, did you ever resolve this? I have the same issue... cuts 3 or 4 spot on then loses the index, then finds it again. Everyone says noise and pulse issue... but I believe there is something wrong with Linuxcnc under G76... especially when it can't keep the trajectory velocity.
8 years 10 months ago #103194 by Patrik T
Replied by Patrik T on topic Unable to cut correct thread with G76
cadcam, no, I did not resolve it.
I am not sure what you are describing is the same issue I have. See the attached photo, this is what happens for me.
The left thread is G76, you see at the root of the thread that consecutive cuts do not sync the same so there are multiple "roots". The right thread is another algorithm where the sync stays good and the root is cut in the same place every cut.
8 years 10 months ago #103203 by andypugh
Replied by andypugh on topic Unable to cut correct thread with G76
How did you change the algorithm? (And where?)
8 years 10 months ago #103205 by cadcam
Thanks Patrick,
Yeah, it's a similar issue with multiple roots that run parallel to each other. I don't believe it's a backlash issue either.
8 years 10 months ago #103206 by Patrik T
Oh, it does look the same for you.
I have some backlash in that lathe but both threads in the picture are cut in the same lathe and with the same setup.
I did not change the G76 algorithm. I have a separate code for moving and syncing the tool in my Xbox pendant implementation.
This code uses the same spindle encoder signal, but jog counts to sync the tool to the spindle absolute position.
Time to create page: 1.952 seconds
