G76 doesn´t work right
9 years 4 days ago #100937 by Skyline
Replied by Skyline on topic G76 doesn´t work right
Okay, so, if i understand right:
I add a 1 PPR (for indication?) to phase Z, the 62 PPR stays A and so i get the second option you listet? The tracking will be better then with only 1 PPR.?
9 years 4 days ago - 9 years 4 days ago #100938 by PCW
Replied by PCW on topic G76 doesn´t work right
Yes, the tracking will be better because the spindle position is updated 62 times per revolution
rather than just once.
With 1 PPR you basically have to guess the spindle position by using the velocity calculated from the
previous revolution and the time from the last index ( That's what position-interpolated is )
Using position-interpolated may still be helpful even at 62 PPR, especially at low speeds
( so you avoid noticeable steps in the z motion )
Last edit: 9 years 4 days ago by PCW.
9 years 4 days ago #100939 by Skyline
Okay, now i got it. I will try to improvise a 1 PPR encoder and test it.
Very much thanks at this point!!!! :):)
9 years 3 days ago #100976 by Skyline
That´s it! My improvise mounted sensor works and a thread was never that sexy before :D
Thank you!
Time to create page: 3.506 seconds
