- Thank you received: 3
How to reset 5221, 5222 and 5223 parameters (G54)?
- nicokid
I think you meant writing L2 and L20.Todd Zuercher wrote: G2 sets the G5x offset to the values you specify. So X0 clears the X offset. G20 sets the current axis location to the value specified. Think touch off.
But I still do not understand the difference. What is the difference between these two commands?
Thanks.
Nicola.
The other sets the #522x parameters such that the current machine position becomes the given values.
- nicokid
So in this case X0 works:andypugh wrote: One sets the #522x parameters to the given values
G10 L20 P1 X0
In this case X0 is wrong:
G10 L2 P1 X0
The right command is:
G10 L2 P1 X
I understood right?
Thanks and happy holidays.
Nicola.
- Thank you received: 1480
For example using this command to touch off the right side of the piece.
You would type G10L2P1X0, if you wanted that point to be 0 in your G54 work coordinate system.
If you were locating off a hole 1" from where you want the edge to be you could enter G10L2P1X1.
- nicokid
OK, but I still do not understand what the difference is between L2 and L20. However it does not matter, I use L20 and I think it does its job.Todd Zuercher wrote: No, The X must have a number after it.
Thanks and happy new year
Nicola.
