How to save machine coordinates with tool length compensation?
7 years 10 months ago #122987 by 3D-Master
Hello,
how can i save the machine coordinates (g53, not g54 - g59.3) where the touch probe is atm. ?
For example:
touch probe is at x30 then touches in x+ direction until it hits the part, then backs off and touches off again, then set zero and then go back to x30 in machine coordinates.
thanks
7 years 10 months ago #122989 by Grotius
Hi 3d master,
G53 has no data. It has nothing. But you can save data if you want to.
I give you a short example :
axis.x.pos-cmd
If you connect this float value to your input 3D.comp file. It will do your trick. After that you must output is somewhere, but
that is up to you.
The following user(s) said Thank You: MaHa
7 years 10 months ago #122997 by MaHa
Or, what i use in my probing routines, to read out actual G53 startposition:
G28.1 returns xyz values to parameter #5161 #5162 #5163
The following user(s) said Thank You: 3D-Master
7 years 10 months ago #123010 by newbynobi
There are several offsets you will need to take care off.
- axis position
- G5X.offset
- tool offset
- may be even a XY rotation
Norbert
7 years 10 months ago #123016 by 3D-Master
7 years 10 months ago #123021 by KCJ
LinuxCNC returns the results of a probe in the current WCS, which unfortunately is not consistent with most other controls. Even though LinuxCNC uses the same gcode (G38) and result parameters (#5061-5069) as Fanuc controls, Fanuc probes in machine coords, while LCNC probes in the current WCS. This has tripped me up more than once!
Several of the main devs and I discussed possible solutions, including adding parameters to LCNC for the probed pos in machine coords (seb has a branch where he started to implement this), or even changing the current behaviour to be fully compatible with Fanuc. The full discussion thread is in the dev mailing list. No additional progress has been made, and I don't expect any.
Workaround
A workaround I came up with was to make use of parameter indirection to get the offset of the currently active WCS and add the probed pos value to that to get the probed pos in ABS coords.
Calculate ABS z pos at which probe tripped:
#<abs_probed_z_pos> = #[5203 + [20 * #5220]] + #5063
If you need the probed post for other axes simply replace the x below with the axis number. (x = 1, y = 2, z = 3 ....)
#<abs_probed_pos> = #[520x + [20 * #5220]] + #506x
Cheers,
Kurt
Time to create page: 0.106 seconds
