G10 L2 P1 question .
- tony978
7 years 8 months ago #125961
by tony978
G10 L2 P1 question . was created by tony978
With the G10 L2 P1 I know x,y can be rotated what about y,z ? The application is for offsetting for my a axis not being parallel with x .
thank you
thank you
- BigJohnT
- Thank you received: 994
7 years 8 months ago #125964
by BigJohnT
Replied by BigJohnT on topic G10 L2 P1 question .
No only X,Y can be rotated.
JT
JT
The following user(s) said Thank You: tony978
- Thank you received: 4153
7 years 8 months ago #125976
Somewhere on the forum is a component I helped write that corrected for X & Y being out of square. Maybe you can find it as it might solve your problem very easily.
Replied by rodw on topic G10 L2 P1 question .
tony978 wrote: With the G10 L2 P1 I know x,y can be rotated what about y,z ? The application is for offsetting for my a axis not being parallel with x .
thank you
- tony978
7 years 8 months ago #126001
by tony978
I have Jerry's routines for probing so I'm good with x,y skew . I was hoping to be able to tweak z moves . It will have to be adjusted in the part model from the sounds of it or maybe in the hal files . But not by g-code , From my understanding
Replied by tony978 on topic G10 L2 P1 question .
thank you
- tony978
7 years 8 months ago #126021
by tony978
so how is this mapping working ?so there is z comp for surface mapping !
- pl7i92
- Thank you received: 358
7 years 8 months ago #126339
by pl7i92
Replied by pl7i92 on topic G10 L2 P1 question .
you can look her is set up a G10 tutorial
there is alsa a Autozero routine
www.youtube.com/channel/UCGuJsIoXW-exBAwdn38dXow/videos
Time to create page: 1.290 seconds
