internal variable for units setting (g20/21)?
04 Mar 2019 19:41 #127722 by IrishMoss
This is probably a silly question, but I'll ask anyway.
Is there any internal variable that stores the current units setting that a program is running in?
I'm asking because i'm creating a custom toolchange-probe subroutine, and I'm using some inch values (my machine also defaults to inches), so my subroutine issues a G20(just to be safe). If the calling file is running under G21, then I'd set back to G21 before exiting the subroutine, if not, then leave it at inches.
It's not critical, since i can add the line manually since i'm editing the file anyway, more of a little nice-to-have, to make the code a little cleaner.
thanks.
04 Mar 2019 19:45 #127723 by MaHa
#<_metric> - Return 1 if G21 is on, else 0.
#<_imperial> - Return 1 if G20 is on, else 0.
The following user(s) said Thank You: IrishMoss
04 Mar 2019 19:49 #127724 by IrishMoss
Replied by IrishMoss on topic internal variable for units setting (g20/21)?
you sir, are awesome.
thank you. :)
07 Mar 2019 14:04 #127977 by IrishMoss
just found an even more elegant way. M73
Haven't tested it yet, but it sounds like it will do exactly what I want. Save state, and return to original settings at the end of the subroutine.
07 Mar 2019 16:21 #127994 by pl7i92
a subroutine shoudt always be filled with the mashine units
if it is presented to a libary like here in the Forum
First line #UNITS in ****
so people using it can detact
or you go for a Factor in First hand so only factor is to set
Time to create page: 0.259 seconds
