Generating G-code for multi-axis robot
7 years 7 months ago #129119 by Grotius
Replied by Grotius on topic Generating G-code for multi-axis robot
Okey, if you go to try EO stop right now. There is a version for you that can move like backward's. If you don't have this version
with your robot you miss a pointer. The combi version is Reverse Adaptive Feed + integrated Externall Offsets. And there is one place on the planet to get it.
If you have some drawings and dimension's of point's and joint's we can look at the interpolation model quite nice !
7 years 7 months ago #129128 by tommylight
Replied by tommylight on topic Generating G-code for multi-axis robot
Grotius wrote: The combi version is Reverse Adaptive Feed + integrated Externall Offsets. And there is one place on the planet to get it.
Here
forum.linuxcnc.org/plasma-laser/35449-an...ma-component?start=0
Either way, i think that you can make everything work with the normal version, as it seems that you need to do different movement for different drinks, you just need to do O subs and call them as needed or depending on what button you press, or depending on the temperature ( warning you do need a temperature sensor and an analogue input, now most people will say that there is no analogue input on a PC, but there are at least 2 always! Sound card! ), or whatever you can think off.
The temperature thing was just an example.
7 years 7 months ago #129142 by pl7i92
Replied by pl7i92 on topic Generating G-code for multi-axis robot
if you build the mashine the way to stay all axis in rotation points
many CAM systems are able to use TCP as a stuff
no offsets needed
like here
7 years 7 months ago #129289 by Grotius
This is i think the only version available :
github.com/grotius-cnc/stable
It has reverse_feed and external_offset's in one version.
7 years 7 months ago #129354 by pl7i92
can you do some example
or even a Video on how to use
Time to create page: 2.887 seconds
