- Thank you received: 4
Error I have never had before
- allenwg2005
7 years 7 months ago #129303
by allenwg2005
Error I have never had before was created by allenwg2005
Hi Folks,
I am using Fusion 360 w/ the standard LinuxCNC [EMC] post.
I am getting an error I have never had before:
"Can not use G53 with cutter radius comp"
I did change my ini recently to include G54 to do toolchanges in a more convenient place, (can that cause this???)
I'll attach the ngc if it helps.
Thank in advance
Thank in advance
- Grotius
- Thank you received: 2349
7 years 7 months ago - 7 years 7 months ago #129305
by Grotius
Replied by Grotius on topic Error I have never had before
I see an airplane in your logo.
Maybe first do G40. Then do G53.
G40 is cutter compansation off.
linuxcnc.org/docs/2.6/html/gcode/gcode.html#sec:G40
Last edit: 7 years 7 months ago by Grotius.
- allenwg2005
7 years 7 months ago #129308
by allenwg2005
Replied by allenwg2005 on topic Error I have never had before
More of a flying wing than airplane, but I feel ya.
That did the trick, I just don't have a clue why it started this.
Thanks for the assist.
- Thank you received: 7491
7 years 7 months ago #129336
That is a B2 bomber !
Could not upload pic as they are all copyrighted.
Replied by tommylight on topic Error I have never had before
Grotius wrote: I see an airplane in your logo.
- pl7i92
- Thank you received: 358
7 years 7 months ago #129353
by pl7i92
Replied by pl7i92 on topic Error I have never had before
always a good idea to start the G-code with a preamble set to Fusion360
G17 G21 G54 G90 G61 G40 G40 G80 ...
as You like to be set the mashine
S1000 not a bad idee to set a Speed as tools break with no turn
- allenwg2005
7 years 7 months ago #129403
by allenwg2005
That preamble looks like a worthwhile thing to do.
Now, how do I add it to the post?
Went and had a look at the LinuxCNC post and was blown away, I changed a post for Vetric and thought that was a challenge, this Fusion post is way way above my pay grade.
Short of a copy this and paste it (here) sort of step by step is the best I could do.
Also, I was running a ngc file today with three different tools in it, when I get to the end of a tool run the machine stops (just as the code tells it to), it dosen't ask for the next tool or give an opportunity to go foreword with the new tool.
Am I doing something wrong? How do I move on?
My guess is the post is written in a way it will not allow for this.
I'll add a little bit of code to show the issue.
Thanks again.
N1070 G1 Z-0.18 F6.
N1075 G0 Z-0.1084
N1080 G1 Z-0.2 F6.
N1085 G0 Z-0.1284
N1090 G1 Z-0.2067 F6.
N1095 G0 Z0.1
N1100 Z0.3
N1105 M5
N1110 G53 Z0. [color=blue(]It stops here)[/color]
(N DRILL LARGE HOLES)
N1115 M9
N1120 M1
N1125 T13 M6
N1130 T1
N1135 S5000 M3
N1140 G54
N1145 M7
N1150 G0 X5.8046 Y10.4086
N1155 G43 Z0.3 H13
N1160 G0 Z0.1
N1165 Z0.05.
Thanks again.
N1070 G1 Z-0.18 F6.
N1075 G0 Z-0.1084
N1080 G1 Z-0.2 F6.
N1085 G0 Z-0.1284
N1095 G0 Z0.1
N1100 Z0.3
N1105 M5
N1115 M9
N1120 M1
N1125 T13 M6
N1130 T1
N1135 S5000 M3
N1140 G54
N1145 M7
N1155 G43 Z0.3 H13
N1160 G0 Z0.1
N1165 Z0.05.
Time to create page: 1.354 seconds
