K word given for arc in xy plane
7 years 5 months ago - 7 years 5 months ago #132849 by BigDo
K word given for arc in xy plane was created by BigDo
Hi all,
i try to generate GCode for my lathe with inkscape but i got a K-Word error "K word given for arc in xy plane"
can someone explane me why. I don't have Y Axis only X and Z.
% (Header) (Generated by gcodetools from Inkscape.) (Using default header. To add your own header create file "header" in the output dir.) M3 (Header end.) G21 (All units in mm) #8 = 0 (Z axis offset) #6 = 0 (X axis offset) #10 = 1 (XY Scale factor) #11 = 1 (Z Scale factor) #20 = 800.000000 (Feed definition) #22 = 100.000000 (Feed definition) #21 = 500.000000 (Feed definition) (Change tool to Lathe cutter) G01 Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[26.000000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[26.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[25.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[25.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[25.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[25.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[26.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[26.000000*#11+#8] F [#20] G01 X[0.075277*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[25.000000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[25.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[24.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[24.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[24.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[24.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[25.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[25.000000*#11+#8] F [#20] G01 X[0.075277*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[24.000000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[24.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[23.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[23.000000*#11+#8] F [#21] G01 X[23.297202*#10+#6] Z[23.000000*#11+#8] F [#21] G01 X[23.297202*#10+#6] Z[23.000000*#11+#8] F [#21] G02 X[21.475625*#10+#6] Z[23.549688*#11+#8] I[-3.796824*#10] K[-9.289004*#11] F [#21] (<-------ERROR in this LINE) G02 X[19.466553*#10+#6] Z[23.749370*#11+#8] I[-2.009072*#10] K[-10.007175*#11] F [#21] G02 X[17.457502*#10+#6] Z[23.549675*#11+#8] I[0.000000*#10] K[-10.205953*#11] F [#21] G02 X[15.636192*#10+#6] Z[23.000000*#11+#8] I[1.974762*#10] K[-9.835475*#11] F [#21] G01 X[15.636192*#10+#6] Z[23.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[23.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[23.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[24.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[24.000000*#11+#8] F [#20] G01 X[0.075277*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[23.000000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[23.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[22.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[22.000000*#11+#8] F [#21] G01 X[25.159080*#10+#6] Z[22.000000*#11+#8] F [#21] G01 X[25.159080*#10+#6] Z[22.000000*#11+#8] F [#21] G02 X[24.260223*#10+#6] Z[22.545616*#11+#8] I[-5.705306*#10] K[-8.385818*#11] F [#21] G02 X[23.297202*#10+#6] Z[23.000000*#11+#8] I[-4.777206*#10] K[-8.877094*#11] F [#21] G01 X[23.297202*#10+#6] Z[23.000000*#11+#8] F [#20] G02 X[21.475625*#10+#6] Z[23.549688*#11+#8] I[-3.796824*#10] K[-9.289004*#11] F [#20] G02 X[19.466553*#10+#6] Z[23.749370*#11+#8] I[-2.009072*#10] K[-10.007175*#11] F [#20] G02 X[17.457502*#10+#6] Z[23.549675*#11+#8] I[0.000000*#10] K[-10.205953*#11] F [#20] G02 X[15.636192*#10+#6] Z[23.000000*#11+#8] I[1.974762*#10] K[-9.835475*#11] F [#20] G01 X[15.636192*#10+#6] Z[23.000000*#11+#8] F [#21] G02 X[14.673324*#10+#6] Z[22.545613*#11+#8] I[3.813285*#10] K[-9.327907*#11] F [#21] G02 X[13.774649*#10+#6] Z[22.000000*#11+#8] I[4.805343*#10] K[-8.927753*#11] F [#21] G01 X[13.774649*#10+#6] Z[22.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[22.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[22.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[23.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[23.000000*#11+#8] F [#20] G01 X[0.075277*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[22.000000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[22.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[21.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[21.000000*#11+#8] F [#21] G01 X[26.405788*#10+#6] Z[21.000000*#11+#8] F [#21] G01 X[26.405788*#10+#6] Z[21.000000*#11+#8] F [#21] G02 X[25.803098*#10+#6] Z[21.523683*#11+#8] I[-6.984101*#10] K[-7.429127*#11] F [#21] G02 X[25.159080*#10+#6] Z[22.000000*#11+#8] I[-6.364181*#10] K[-7.931339*#11] F [#21] G01 X[25.159080*#10+#6] Z[22.000000*#11+#8] F [#20] G02 X[22.547449*#10+#6] Z[23.270716*#11+#8] I[-5.669695*#10] K[-8.333476*#11] F [#20] G02 X[19.466553*#10+#6] Z[23.749370*#11+#8] I[-3.080896*#10] K[-9.675899*#11] F [#20] G02 X[16.385743*#10+#6] Z[23.270673*#11+#8] I[0.000000*#10] K[-10.153125*#11] F [#20] G02 X[13.774649*#10+#6] Z[22.000000*#11+#8] I[3.057217*#10] K[-9.600340*#11] F [#20] G01 X[13.774649*#10+#6] Z[22.000000*#11+#8] F [#21] G02 X[13.130777*#10+#6] Z[21.523684*#11+#8] I[5.718962*#10] K[-8.404100*#11] F [#21] G02 X[12.528234*#10+#6] Z[21.000000*#11+#8] I[6.380376*#10] K[-7.949641*#11] F [#21] G01 X[12.528234*#10+#6] Z[21.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[21.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[21.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[22.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[22.000000*#11+#8] F [#20] G01 X[0.075277*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[21.000000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[21.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[20.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[20.000000*#11+#8] F [#21] G01 X[27.335990*#10+#6] Z[20.000000*#11+#8] F [#21] G01 X[27.335990*#10+#6] Z[20.000000*#11+#8] F [#21] G02 X[26.887447*#10+#6] Z[20.515814*#11+#8] I[-7.910147*#10] K[-6.425605*#11] F [#21] G02 X[26.405788*#10+#6] Z[21.000000*#11+#8] I[-7.468335*#10] K[-6.947682*#11] F [#21] G01 X[26.405788*#10+#6] Z[21.000000*#11+#8] F [#20] G02 X[23.329398*#10+#6] Z[22.984165*#11+#8] I[-6.937857*#10] K[-7.379937*#11] F [#20] G02 X[19.466553*#10+#6] Z[23.749370*#11+#8] I[-3.862845*#10] K[-9.367445*#11] F [#20] G02 X[15.603889*#10+#6] Z[22.984090*#11+#8] I[0.000000*#10] K[-10.130826*#11] F [#20] G02 X[12.528234*#10+#6] Z[21.000000*#11+#8] I[3.860512*#10] K[-9.360329*#11] F [#20] G01 X[12.528234*#10+#6] Z[21.000000*#11+#8] F [#21] G02 X[12.046706*#10+#6] Z[20.515817*#11+#8] I[6.985726*#10] K[-7.428941*#11] F [#21] G02 X[11.598288*#10+#6] Z[20.000000*#11+#8] I[7.461068*#10] K[-6.939005*#11] F [#21] G01 X[11.598288*#10+#6] Z[20.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[20.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[20.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[21.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[21.000000*#11+#8] F [#20] G01 X[0.075277*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[20.000000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[20.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[19.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[19.000000*#11+#8] F [#21] G01 X[28.052473*#10+#6] Z[19.000000*#11+#8] F [#21] G01 X[28.052473*#10+#6] Z[19.000000*#11+#8] F [#21] G02 X[27.708697*#10+#6] Z[19.511796*#11+#8] I[-8.592449*#10] K[-5.400241*#11] F [#21] G02 X[27.335990*#10+#6] Z[20.000000*#11+#8] I[-8.273797*#10] K[-5.930044*#11] F [#21] G01 X[27.335990*#10+#6] Z[20.000000*#11+#8] F [#20] G02 X[23.970831*#10+#6] Z[22.692378*#11+#8] I[-7.882858*#10] K[-6.403438*#11] F [#20] G02 X[19.466553*#10+#6] Z[23.749370*#11+#8] I[-4.504278*#10] K[-9.068795*#11] F [#20] G02 X[14.962573*#10+#6] Z[22.692275*#11+#8] I[0.000000*#10] K[-10.123633*#11] F [#20] G02 X[11.598288*#10+#6] Z[20.000000*#11+#8] I[4.516846*#10] K[-9.092436*#11] F [#20] G01 X[11.598288*#10+#6] Z[20.000000*#11+#8] F [#21] G02 X[11.225695*#10+#6] Z[19.511799*#11+#8] I[7.900748*#10] K[-6.416092*#11] F [#21] G02 X[10.882025*#10+#6] Z[19.000000*#11+#8] I[8.248894*#10] K[-5.910375*#11] F [#21] G01 X[10.882025*#10+#6] Z[19.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[19.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[19.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[20.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[20.000000*#11+#8] F [#20] G01 X[0.075277*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[19.000000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[19.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[18.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[18.000000*#11+#8] F [#21] G01 X[28.604812*#10+#6] Z[18.000000*#11+#8] F [#21] G01 X[28.604812*#10+#6] Z[18.000000*#11+#8] F [#21] G02 X[28.341885*#10+#6] Z[18.509417*#11+#8] I[-9.098244*#10] K[-4.373342*#11] F [#21] G02 X[28.052473*#10+#6] Z[19.000000*#11+#8] I[-8.866338*#10] K[-4.899902*#11] F [#21] G01 X[28.052473*#10+#6] Z[19.000000*#11+#8] F [#20] G02 X[24.523059*#10+#6] Z[22.396694*#11+#8] I[-8.602346*#10] K[-5.406461*#11] F [#20] G02 X[19.466553*#10+#6] Z[23.749370*#11+#8] I[-5.056506*#10] K[-8.774651*#11] F [#20] G02 X[14.410477*#10+#6] Z[22.396566*#11+#8] I[-0.000000*#10] K[-10.124889*#11] F [#20] G02 X[10.882025*#10+#6] Z[19.000000*#11+#8] I[5.072348*#10] K[-8.800316*#11] F [#20] G01 X[10.882025*#10+#6] Z[19.000000*#11+#8] F [#21] G02 X[10.592709*#10+#6] Z[18.509420*#11+#8] I[8.577400*#10] K[-5.389049*#11] F [#21] G02 X[10.329871*#10+#6] Z[18.000000*#11+#8] I[8.836421*#10] K[-4.881732*#11] F [#21] G01 X[10.329871*#10+#6] Z[18.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[18.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[18.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[19.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[19.000000*#11+#8] F [#20] G01 X[0.075277*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[18.000000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[18.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[17.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[17.000000*#11+#8] F [#21] G01 X[29.020879*#10+#6] Z[17.000000*#11+#8] F [#21] G01 X[29.020879*#10+#6] Z[17.000000*#11+#8] F [#21] G02 X[28.825346*#10+#6] Z[17.507904*#11+#8] I[-9.477710*#10] K[-3.357149*#11] F [#21] G02 X[28.604812*#10+#6] Z[18.000000*#11+#8] I[-9.303971*#10] K[-3.874128*#11] F [#21] G01 X[28.604812*#10+#6] Z[18.000000*#11+#8] F [#20] G02 X[25.010670*#10+#6] Z[22.098163*#11+#8] I[-9.146686*#10] K[-4.396627*#11] F [#20] G02 X[19.466553*#10+#6] Z[23.749370*#11+#8] I[-5.544117*#10] K[-8.481898*#11] F [#20] G02 X[13.923009*#10+#6] Z[22.098015*#11+#8] I[-0.000000*#10] K[-10.130422*#11] F [#20] G02 X[10.329871*#10+#6] Z[18.000000*#11+#8] I[5.552354*#10] K[-8.492542*#11] F [#20] G01 X[10.329871*#10+#6] Z[18.000000*#11+#8] F [#21] G02 X[10.113511*#10+#6] Z[17.517731*#11+#8] I[9.084962*#10] K[-4.365442*#11] F [#21] G02 X[9.921150*#10+#6] Z[17.020260*#11+#8] I[9.280481*#10] K[-3.874472*#11] F [#21] G01 X[9.912735*#10+#6] Z[17.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[17.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[17.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[18.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[18.000000*#11+#8] F [#20] G01 X[0.075277*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[17.000000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[17.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[16.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[16.000000*#11+#8] F [#21] G01 X[29.317659*#10+#6] Z[16.000000*#11+#8] F [#21] G01 X[29.317659*#10+#6] Z[16.000000*#11+#8] F [#21] G02 X[29.181343*#10+#6] Z[16.506914*#11+#8] I[-9.771132*#10] K[-2.355792*#11] F [#21] G02 X[29.020879*#10+#6] Z[17.000000*#11+#8] I[-9.631878*#10] K[-2.861833*#11] F [#21] G01 X[29.020879*#10+#6] Z[17.000000*#11+#8] F [#20] G02 X[25.447300*#10+#6] Z[21.797772*#11+#8] I[-9.548161*#10] K[-3.382104*#11] F [#20] G02 X[19.466553*#10+#6] Z[23.749370*#11+#8] I[-5.980747*#10] K[-8.188317*#11] F [#20] G02 X[13.494923*#10+#6] Z[21.803707*#11+#8] I[-0.000000*#10] K[-10.136896*#11] F [#20] G02 X[9.921150*#10+#6] Z[17.020260*#11+#8] I[5.966787*#10] K[-8.184588*#11] F [#20] G01 X[9.912735*#10+#6] Z[17.000000*#11+#8] F [#21] G03 X[8.508745*#10+#6] Z[16.149795*#11+#8] I[-1.347034*#10] K[0.640085*#11] F [#21] G03 X[0.075277*#10+#6] Z[16.595080*#11+#8] I[11.082808*#10] K[289.987882*#11] F [#21] G01 X[0.075277*#10+#6] Z[17.000000*#11+#8] F [#21] G01 X[0.075277*#10+#6] Z[17.000000*#11+#8] F [#20] G01 X[0.075277*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[16.000000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[16.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[15.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[15.000000*#11+#8] F [#21] G01 X[29.505882*#10+#6] Z[15.000000*#11+#8] F [#21] G01 X[29.505882*#10+#6] Z[15.000000*#11+#8] F [#21] G02 X[29.423660*#10+#6] Z[15.506268*#11+#8] I[-10.011542*#10] K[-1.366150*#11] F [#21] G02 X[29.317659*#10+#6] Z[16.000000*#11+#8] I[-9.886966*#10] K[-1.864431*#11] F [#21] G01 X[29.317659*#10+#6] Z[16.000000*#11+#8] F [#20] G02 X[25.841068*#10+#6] Z[21.496540*#11+#8] I[-9.830537*#10] K[-2.370115*#11] F [#20] G02 X[19.466553*#10+#6] Z[23.749370*#11+#8] I[-6.374515*#10] K[-7.892121*#11] F [#20] G02 X[13.494923*#10+#6] Z[21.803707*#11+#8] I[-0.000000*#10] K[-10.136896*#11] F [#20] G02 X[9.921150*#10+#6] Z[17.020260*#11+#8] I[5.966787*#10] K[-8.184588*#11] F [#20] G03 X[8.613532*#10+#6] Z[16.136761*#11+#8] I[-1.254427*#10] K[0.447192*#11] F [#20] G03 X[0.075277*#10+#6] Z[16.595080*#11+#8] I[12.487154*#10] K[312.390329*#11] F [#20] G01 X[0.075277*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[15.000000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[15.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[14.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[14.000000*#11+#8] F [#21] G01 X[29.592309*#10+#6] Z[14.000000*#11+#8] F [#21] G01 X[29.592309*#10+#6] Z[14.000000*#11+#8] F [#21] G02 X[29.561006*#10+#6] Z[14.505858*#11+#8] I[-10.225956*#10] K[-0.378895*#11] F [#21] G02 X[29.505882*#10+#6] Z[15.000000*#11+#8] I[-10.099641*#10] K[-0.876508*#11] F [#21] G01 X[29.505882*#10+#6] Z[15.000000*#11+#8] F [#20] G02 X[26.196915*#10+#6] Z[21.195553*#11+#8] I[-10.012866*#10] K[-1.366330*#11] F [#20] G02 X[19.466553*#10+#6] Z[23.749370*#11+#8] I[-6.730362*#10] K[-7.591734*#11] F [#20] G02 X[13.494923*#10+#6] Z[21.803707*#11+#8] I[-0.000000*#10] K[-10.136896*#11] F [#20] G02 X[9.921150*#10+#6] Z[17.020260*#11+#8] I[5.966787*#10] K[-8.184588*#11] F [#20] G03 X[8.613532*#10+#6] Z[16.136761*#11+#8] I[-1.254427*#10] K[0.447192*#11] F [#20] G03 X[0.075277*#10+#6] Z[16.595080*#11+#8] I[12.487154*#10] K[312.390329*#11] F [#20] G01 X[0.075277*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[14.000000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[14.000000*#11+#8] F [#21] G01 X[29.599365*#10+#6] Z[13.618510*#11+#8] F [#21] G02 X[29.597588*#10+#6] Z[13.810081*#11+#8] I[-10.329344*#10] K[0.000000*#11] F [#21] G02 X[29.592309*#10+#6] Z[14.000000*#11+#8] I[-10.274896*#10] K[-0.190594*#11] F [#21] G01 X[29.592309*#10+#6] Z[14.000000*#11+#8] F [#20] G02 X[26.517776*#10+#6] Z[20.895974*#11+#8] I[-10.111173*#10] K[-0.374642*#11] F [#20] G02 X[19.466553*#10+#6] Z[23.749370*#11+#8] I[-7.051223*#10] K[-7.285685*#11] F [#20] G02 X[13.494923*#10+#6] Z[21.803707*#11+#8] I[-0.000000*#10] K[-10.136896*#11] F [#20] G02 X[9.921150*#10+#6] Z[17.020260*#11+#8] I[5.966787*#10] K[-8.184588*#11] F [#20] G03 X[8.613532*#10+#6] Z[16.136761*#11+#8] I[-1.254427*#10] K[0.447192*#11] F [#20] G03 X[0.075277*#10+#6] Z[16.595080*#11+#8] I[12.487154*#10] K[312.390329*#11] F [#20] G01 X[0.075277*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] (Fine cutting start) (Calculating fine cut using Move path) (Fine cut 1-th cicle start) G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[13.768510*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[13.468510*#11+#8] F [#22] G01 X[29.599365*#10+#6] Z[13.468510*#11+#8] F [#22] G02 X[26.631328*#10+#6] Z[20.632315*#11+#8] I[-10.129480*#10] K[0.000000*#11] F [#22] G02 X[19.466553*#10+#6] Z[23.599370*#11+#8] I[-7.164775*#10] K[-7.167138*#11] F [#22] G02 X[13.494923*#10+#6] Z[21.653707*#11+#8] I[-0.000000*#10] K[-10.136896*#11] F [#22] G02 X[9.921150*#10+#6] Z[16.870260*#11+#8] I[5.966787*#10] K[-8.184588*#11] F [#22] G03 X[8.613532*#10+#6] Z[15.986761*#11+#8] I[-1.254427*#10] K[0.447192*#11] F [#22] G03 X[0.075277*#10+#6] Z[16.445080*#11+#8] I[12.487154*#10] K[312.390329*#11] F [#22] G01 Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] (Fine cut 2-th cicle start) G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[13.618510*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[13.318510*#11+#8] F [#22] G01 X[29.599365*#10+#6] Z[13.318510*#11+#8] F [#22] G02 X[26.631328*#10+#6] Z[20.482315*#11+#8] I[-10.129480*#10] K[0.000000*#11] F [#22] G02 X[19.466553*#10+#6] Z[23.449370*#11+#8] I[-7.164775*#10] K[-7.167138*#11] F [#22] G02 X[13.494923*#10+#6] Z[21.503707*#11+#8] I[-0.000000*#10] K[-10.136896*#11] F [#22] G02 X[9.921150*#10+#6] Z[16.720260*#11+#8] I[5.966787*#10] K[-8.184588*#11] F [#22] G03 X[8.613532*#10+#6] Z[15.836761*#11+#8] I[-1.254427*#10] K[0.447192*#11] F [#22] G03 X[0.075277*#10+#6] Z[16.295080*#11+#8] I[12.487154*#10] K[312.390329*#11] F [#22] G01 Z[30.300000*#11+#8] F [#20] G01 X[29.599365*#10+#6] Z[30.300000*#11+#8] F [#20] (Footer) M5 G00 X20.0000 Z0.0000 M2 (Using default footer. To add your own footer create file "footer" in the output dir.) (end) %
Niko
PS: i tried to add a SVG-File but got a error "Unable to get properties for the image."
Last edit: 7 years 5 months ago by BigDo.
7 years 5 months ago - 7 years 5 months ago #132857 by Hakan
Replied by Hakan on topic K word given for arc in xy plane
Try setting G18 for ZX plane
linuxcnc.org/docs/html/gcode/g-code.html#gcode:g17-g19.1
I have G18 set in the startup code in the ini file for my lathe
Last edit: 7 years 5 months ago by Hakan.
The following user(s) said Thank You: BigDo
7 years 5 months ago #132869 by BigJohnT
Replied by BigJohnT on topic K word given for arc in xy plane
In the XY plane the offsets are I and J for G2/3 arcs. Check inkscape to make sure your settings are correct.
linuxcnc.org/docs/devel/html/gcode/g-code.html#gcode:g2-g3
JT
Time to create page: 2.201 seconds
