accessing variables in Ini files from python
  • rockandsalt
  • Topic Author
  • New Member
  • New Member
7 years 5 months ago #133108 by rockandsalt
I would like to know if it is possible to access variables in the INI file using python.
I know it can be done using O-word in this example .
cheers
7 years 5 months ago #133126 by pl7i92
welcome frech boarder and deep dive into
import sys import linuxcnc inifile = linuxcnc.ini(sys.argv[1]) # inifile.find() returns None if the key wasnt found - the # following idiom is useful for setting a default value: machine_name = inifile.find('EMC', 'MACHINE') or "unknown" print "machine name: ", machine_name # inifile.findall() returns a list of matches, or an empty list # if the key wasnt found: extensions = inifile.findall("FILTER", "PROGRAM_EXTENSION") print "extensions: ", extensions # override default NML file by ini parameter if given nmlfile = inifile.find("EMC", "NML_FILE") if nmlfile: linuxcnc.nmlfile = os.path.join(os.path.dirname(sys.argv[1]), nmlfile)
The following user(s) said Thank You: rockandsalt
7 years 5 months ago #133205 by BigJohnT
4 years 9 months ago #230859 by harry4516
Replied by harry4516 on topic accessing variables in Ini files from python
gives an error message: index out of range
is there any change in the actual linuxcnc version, or what is missing?
3 years 1 day ago - 3 years 1 day ago #284333 by Talla
Hallo Harry,
u can use the path to your machine.ini.
Example:
inifile = linuxcnc.ini('/home/cnc/linuxcnc/configs/testmachine/testmachine.ini')
greetings Peter
Last edit: 3 years 1 day ago by Talla.
Time to create page: 0.170 seconds
