M03, M05 showing red in editor
- soram
7 years 5 months ago #133388
by soram
M03, M05 showing red in editor was created by soram
First time here! I have my mill now running machinekit on a Beaglebone with GMOCCAPY.
So I can move and start everything using manual and MDI modes. I wanted to write a short program but when I load it and try to run the M03 and M05 commands are blocked red in the editor and the program won't run. I can issue those commands fine in MDI mode however.
Any insight here much appreciated.
Stephen
Stephen
- pl7i92
- Thank you received: 358
7 years 5 months ago #133517
by pl7i92
Replied by pl7i92 on topic M03, M05 showing red in editor
hi you can get the profile editor
like here
like here
- soram
7 years 5 months ago #133637
by soram
Replied by soram on topic M03, M05 showing red in editor
Thanks - I had thought there was an issue with the codes hence the red but it appears they just appear red anyway. I had a couple of other issues with the file but managed to sort them out so that it now runs fine.
Cheers
Cheers
- pl7i92
7 years 5 months ago #133857
by pl7i92
Nise can you mark the Topic Solved please
- soram
7 years 5 months ago #133956
by soram
How?
- Thank you received: 7491
7 years 5 months ago #134225
Replied by tommylight on topic M03, M05 showing red in editor
Post a reply with solved but also add that to the title, above where you normally write.soram wrote: How?
Time to create page: 1.818 seconds
