Run from line problem
6 years 8 months ago #156764 by MaHa
Replied by MaHa on topic Run from line problem
As i didn't like anymore to enter the data for run from line filter and probing positions on top of the .ngc routine, i made this slim sidepanel to control that. It fits the fhd screen and is working without problems. New, i can auto add the last F, S, Offset and much more, if desired. Which gives full control to restart in any situation. A message is displayed, about the required tool.
Mostly restart by: check add last F S G, check G43, enter Targetline, Run File. Occasionally enter X Y position, to have a controlled movement to near starting point.
Only one behaviour of motion.program-line, if a sequence is running single block and passing a subroutine, after motion.program-line is always zero. Releasing and starting sb again solves that.
The following user(s) said Thank You: andypugh, Todd Zuercher, HalaszAttila
6 years 6 months ago #162719 by MaHa
Did a lot of work, using the new sidepanel, it is perfect for my workflow, break, redo or continue is simple now. Only had to do some minor modifications.
I managed to always display the highest number of motion.program-line, and it stays displayed on break, reseted by reload file.
Toolchange and toolprobing position adjust by slider works fine. Now i save the values, after restart recover the selected positions.
Have the filter turned on and loading a new ngc file is no good. The filename is saved to a temp file now, when load a new file
compare with argv[0]. The message component is used to remind me, if the filter is on when loading a new file. I feel now, the air is getting thinner for more improvements.
5 years 9 months ago - 5 years 4 months ago #197151 by MaHa
Screenshot from my documentation for the sidepanel. Redframed, the options to be displayed.
Minor modifications on the RunFromLineFilter, works very good now and is extensively used.
I did some extensions of the panel during the year, then felt like cleaning up and removing some. Only a few images to display operating mode, motion type and the moving axis are left, providing clarity about current operating mode and motion. On the other hand, added some tabs for tool and offset fine correction. The tab for probing tool and offset before running a program, solves the problem with inconsistent preview/toolpath, which otherwise won't be congruent.
Using slider,checkbox and radiobutton reduces the effort needed to check the entered data for integrity. All OK button can get armed only when not in auto mode, and are auto disabled after, so almost no accidentally corrections possible. Logging offsets, corrections and probing results. Easy to undo the history, if required.
Anyway, it's about machining parts and not starring at features on screen. Very useful with pyvcp, Ctrl + E makes the panel disapear, if required.
Very basic, slim keyboard, mouse and no touchscreen
And finally the timers are running
Monitoring tool operating time:
motion.current-vel spindle.0.on motion.motion-type 2 or 3 (G1 G2 G3)
all 3 must be active to count tool operating time.
Reset timer on toolchange
For Tool operating time, i modified the time component to return only time in minutes. For Log, the operating time for tools is saved in a file with tools ascending. Another file, has an entry for each tool/time.
Check another item on to do list. The Notification popup, hiding parts of the sidepanel. shifted by edit /usr/bin/axis (py) line 337, enter an -X value.
Appearance before and after
Last edit: 5 years 4 months ago by MaHa.
The following user(s) said Thank You: HalaszAttila
3 years 9 months ago #261504 by MaHa
My project, 'run from line filter' is still making progress, is integrated in the workflow. Sometimes change or add a feature.
If the filter is on, program lines are read, until target line, selected commands and values sampled, except after G10, semikolon and open bracket. (Don't read comments or coordinates after G10)
Create a preamble for restart with sampled:
  •  rapid / linear / Arc  G0 / G1 / G2 / G3
  •  distance mode         G90 / G91
  •  coordinate system     G54 - G59.3
  •  plane                 G17 G18 G19
  •  feed rate mode        G93 / G94
  •  spindle speed         S
  •  spindle control       M3 / M5
  •  feed                  F
  •  tool length comp      G43 / G49
  •  path blending         G64 Pn
  •  units                 G20 / G21
Error- checking for 'is on'   (cancel file output but print something like:  print " M2 ;ERROR - G41 / G42  is ON")
  •  G91
  •  G41 / G42
  •  Canned Cycle
  •  Required Tool not loaded
If a new file is loaded, the filter turns off
Possible to load 6 lines from before target line. Can be used for lines with Toolchange, probing, setting variables....
Set X and Y coordinates for move to position before targetline.
The new stuff:
A component, showing the (virtual) linenumber from the original file (targetline minus added lines plus motion.program.line)
It is reset by restart or a new file loaded.
Also possible now to restart with arc moves. Some 3d jobs include so many G2 G3 moves. To restart with, (no cuttercompensation G41 G42 used), set the linenumber with last X Y (end_of_arc) before target line.
If the target line has no G2 G3, the sampled command is inserted.
The option, repos to last Z position, is done with sampled feed. Here a yesno box apears, need to confirm the Z movement to last Z pos.
Years ago, i used run from here, rammed an endmill through an expensive part and almost through the old machines table, also had to realign geometry. Then started testing workarounds. The first attemps were awkward to use. Now is simple. Just do the settings, reload, start.
A sample how the panel looks at the moment, and the formating of the file with inserted lines, marked to recognize them and double check before run.
Time to create page: 0.136 seconds
