Lathe stops at code line
7 years 4 months ago #137055 by Erikcnc
Replied by Erikcnc on topic Lathe stops at code line
I have getting it to work now!
On the mesa 7i76e board there are 3 Jumpers. W10 W11 and W13.
on the left is single mode, to the right is differential mode.
in halshow i can now see the position and the channel A and B signals.
unfortunately no Z Index signal and no real time rpm.
7 years 4 months ago #137239 by andypugh
Replied by andypugh on topic Lathe stops at code line
It is practically impossible to see a Z pulse.
You can test by using halcmd to setp the index-enable, then turn the spindle by hand and watching for index-enable to go false again.
Does your spindle position increase by 1.0 per turn?
Time to create page: 0.131 seconds
