Radius to end of arc differs from radius to start error
7 years 4 months ago - 7 years 4 months ago #137390 by shogan50
I ran this part program a few days ago with out issue. Now I get this error. Any help appreciated. LINK TO SCREEN SHOT OF ERROR Something is causing it to think it is starting at x110.2089 on line N70.
% (RAPIER) (T1 D=12.7 CR=0. - ZMIN=-22.55 - FLAT END MILL) N10 G90 G94 G17 G91.1 N15 G21 N20 G53 G0 Z0. (PARALLEL2) N25 M9 N30 T1 M6 N35 S18000 M3 N40 G54 N45 M8 N50 G0 X217.826 Y-32.099 N55 G43 Z15. H1 N60 G0 Z1. N65 G1 Z0.27 F3000. N70 G18 G3 X216.557 Z-1. I-1.27 K0. N75 G1 X210.019 Z-1.004 N80 X-116.054 Z-8.635 N85 G3 X-117.354 Z-7.365 I-0.03 K1.27 N90 G0 Z5. N95 X-184.161 Y-25.755 N100 Z-8.228 N105 G1 Z-8.929 F3000. N110 G2 X-182.861 Z-10.198 I1.27 K0. N115 G1 X210.019 Z-1.004 N120 X216.557 Z-1.
Last edit: 7 years 4 months ago by shogan50.
7 years 4 months ago #137391 by shogan50
BTW, I tried to attach a file several times, but it timed out and I lost my post. The file was within size limits. A larger version is linked in the original text.
Two possible relevant items. I accidentally typed a G10L10P1X0Y0Z0 rather than a G10L20. I've not done much with the machine or ini file in between. Feels like some modal setting. I've read the posts on radii tolerance, but this is off by 100mm.
7 years 4 months ago #137420 by shogan50
No one has responded, but for those who might encounter in the future, I'm pretty sure I figured it out. I won't know for sure until I get home and test, but N55 turns on cutter compensation after the G0 move on N50. If I did indeed type G10L10P1X0Y0Z0, then there are X and Y offsets in the tool table and my money is that the magnitude of X is about 106.4mm. The post processor didn't anticipate non-zero x and y offsets in the tool table.
  • Moderator
  • Moderator
7 years 4 months ago #137427 by tommylight
Usually that error is for to big tool for a small radius, or something wrong with offsets, or trying to start an arc at an inconvenient position.
7 years 4 months ago #137681 by shogan50
That was indeed it the problem.
Time to create page: 0.268 seconds
