G-code and driving robots.
7 years 1 month ago #145344
Replied by andypugh on topic G-code and driving robots.
linuxcnc.org/docs/2.8/html/motion/5-axis-kinematics.html
(Though there is a lot of maths that you don't need to understand to use the kinematics modules)
Also:
linuxcnc.org/docs/2.8/html/man/man9/kins.9.html
And:
linuxcnc.org/docs/2.8/html/motion/kinematics.html
Also:
And:
- jaxonusa
7 years 1 month ago #145353
by jaxonusa
Replied by jaxonusa on topic G-code and driving robots.
Can I use the vectors from section 3 of
in a way sort of like this:
G01 Qx Qy Qz Kx Ky Kz
Or maybe like this:
G01 XQx YQy ZQz IKx JKy KKz
Or maybe like this:
7 years 1 month ago #145358
No. The G-code _has_ to use XYZABC. But the variables mean very much the same thing.
The following user(s) said Thank You: jaxonusa
- jaxonusa
7 years 1 month ago #145359
by jaxonusa
I very much appreciate the honesty of your answer. I must disagree with you though. I mean to do so in the nicest possible terms. IJK an ABC "do the same thing," but are very different. It is a somewhat easy task to calculate ABC from IJK, but they are not the same. IJK are the same units of the part, inches, or mm, or something like that. ABC are rotations, in degrees or radians or something like that.
If Kx, Ky, and Kz can be left in the G code, and somehow passed in to the kinematics, it would unlock a whole lot wonderful functionality. All the math shown in the link would still hold true, be exactly the same, just split up a little bit differently.
7 years 1 month ago - 7 years 1 month ago #145380
They do the same thing, in that they define a position and direction in space.
The G-code interpreter does accept IJK. but they define the position of an arc centre from the current position. (and, sadly, only in 3 planes, though there was some work done some time ago on allowing 3D arcs)
It would be relatively easy to re-map an unused G-code (G1.1?) such that G1.1 Xx Yy Zz Ii Jj Kk was interpreted as a G1 Xx Yy Zz A(f(ijk)) B(f(ijk)) C(f(ijk))
Or you could add an input filter to LinuxCNC that converts files in a format convenient to you to a format that is compatible with the LinuxCNC interpreter.
Here is an example of a file filter: forum.linuxcnc.org/38-general-linuxcnc-q...r-me?start=10#120524
And then there is the possibility of writing a whole new LinuxCNC interpreter, there is provision for "pluggable" interpreters and there was at one point a project to write a STEP-NC interpreter.
Last edit: 7 years 1 month ago by andypugh.
Time to create page: 0.186 seconds
