geting line number from extending gcode.
- thang
- Thank you received: 11
28 Aug 2019 01:43 #143384
by thang
geting line number from extending gcode. was created by thang
Base on:
www.vdwalle.com/Norte/Structure.html#_in...r_by_remapping_codes
I tried create new gcode and it worked. there is only 1 problem that i cant find the line number of new gcode. lineno() function just return line number in python script file not gcode file. Is there any way to get line number of my new gcode command?
- Thank you received: 2181
28 Aug 2019 04:55 #143395
Replied by cmorley on topic geting line number from extending gcode.
You might need to give us a little more to go on.
What are you trying to do?
Chris
Chris
- thang
28 Aug 2019 06:33 #143398
by thang
Replied by thang on topic geting line number from extending gcode.
i create a gcode command name "g0.1". This command use G1 command to move machine in a paterm(like square, triangle). In command "self.excuse(G1 x y z,linenumber)" there is an argument that allow me set line number,i want to use it to highlight command "g0.1" when program reach this command.
28 Aug 2019 06:48 - 28 Aug 2019 06:49 #143400
So you created a remap program to feed linuxcnc a gcode program but you need to know what line on the gcode program it is running?
That's my guess anyways.
Remap is one of the most cutting-edge things an integrator can use.
We would need much more detail to help, like to see the remap code.
Chris M
Chris M
Last edit: 28 Aug 2019 06:49 by cmorley.
28 Aug 2019 06:53 #143401
oh wait - do you mean when running linuxcnc normally, you want your new gcode to be highlighted?
- thang
28 Aug 2019 07:01 - 28 Aug 2019 07:10 #143403
by thang
yes, i want to this command is highlighted. Currently it highlight previous gcode command if i dont give line_number in command self.excuse(). So i need to find a function in module emccanon or interpreter or what ever that give me the line_number
Last edit: 28 Aug 2019 07:10 by thang.
28 Aug 2019 07:10 #143404
There is no universal way to do this. Any highlighting is done by the display screen being used, not by linuxcnc.
You could surely program gladevcp's sourceview widget to search for and highlight whatever you want but it would require custom coding - AXIS would be more difficult.
but gladevcp sourcview does use color coding for gcode and possible you could use that to at least color the gcode differently. I'm sorry I don't have a reference for that - but you might check linuxcnc's wiki or google.
Chris M
Chris M
- thang
28 Aug 2019 07:26 #143407
by thang
As i know, gladevcp sourceview use "motion_line" in module linuxcnc python interface to get executing line of gcode. And this stat is created somewhere
28 Aug 2019 07:39 #143409
yes linuxcnc's status messages are used in gladevcp, but I don't actually know where it originates from, but possibly motion.
Chris M
Chris M
Time to create page: 0.098 seconds
