- Thank you received: 9
M code help
- aluplastvz
7 years 1 month ago #146432
by aluplastvz
Replied by aluplastvz on topic M code help
- Thank you received: 7491
7 years 1 month ago #146465
Replied by tommylight on topic M code help
Nice !
You could mark the thread as solved, and upload your config files.
Thank you.
Srbian:
Fino !
Mozes da napises da je reseno, i da postavis config fjalove.
Hvala.
Thank you.
Srbian:
Fino !
Hvala.
- aluplastvz
7 years 1 month ago #146500
by aluplastvz
Hello
It's not over this is one part until I complete the whole line.
The next thing I need is an automatic correction of the x-z table against the z in case it is not straight because the length of the board is 6000mm. It would use an optical / laser sensor to find the edge of the glass.
Maybe someone has a solution or to help.
Hello
Hello
- aluplastvz
7 years 1 month ago - 7 years 1 month ago #146501
by aluplastvz
I'm out of the workshop right now in two days and I'm going to set ini and hal, maybe help someone
Hello
Hello
Last edit: 7 years 1 month ago by aluplastvz.
- aluplastvz
6 years 1 month ago #181826
by aluplastvz
The following user(s) said Thank You: phillc54, tommylight, Clive S, Aciera
- Mike_Eitel
- Thank you received: 183
6 years 1 month ago #181866
by Mike_Eitel
Replied by Mike_Eitel on topic M code help
That is a very nice industrial application. Did you solve everithing with lcnc and Classic ladder. Or did you additionaly implemented a plc.
Congratulations
Mike
Congratulations
Mike
Time to create page: 0.232 seconds
