G code confusion
  • Dinuka_Shehan
  • Dinuka_Shehan's Avatar Topic Author
  • Platinum Member
  • Platinum Member
24 Sep 2019 15:30 #146082 by Dinuka_Shehan
G code confusion was created by Dinuka_Shehan
Are there any variations of g codes to system to system.
I am confused about it.is not it a universal machine language.
"When machining a screw thread on a CNC lathe we have a few options. Depending on the version of the FANUC controls, we can use one line of code or two. Both methods use the G76 command and contain information that tells the machine controls the details of the thread that we wish to cut. Thread cutting can also be performed using a G32 G Code and G92. We will take a look at how these works along with the more common G76"
Copied from this link.
gcodetutor.com/cnc-machine-training/g76-thread-cycle.html
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
24 Sep 2019 15:31 #146083 by Dinuka_Shehan
Replied by Dinuka_Shehan on topic G code confusion
FANUC and Linux cnc different each other?
  • Moderator
  • Moderator
24 Sep 2019 15:53 - 24 Sep 2019 15:54 #146084 by tommylight
Replied by tommylight on topic G code confusion
Fanuc uses different gcode for different machines, so yes they are different in some cases.
Fanuc punch press: T5 LAA 45 20 25 <<< means Tool 5 (round 8mm) Line At Angle of 45 degrees 20 holes at 25mm centre distances.
It also use Grid and other sch commands.
Fanuc for a mill or lathe can not use such gcode, although it is Fanuc.
Last edit: 24 Sep 2019 15:54 by tommylight.
The following user(s) said Thank You: Dinuka_Shehan
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
24 Sep 2019 16:24 - 24 Sep 2019 16:25 #146094 by Dinuka_Shehan
What is the name of the gcode which we are using in Linux cnc.
Last edit: 24 Sep 2019 16:25 by Dinuka_Shehan.
  • Moderator
  • Moderator
24 Sep 2019 16:33 #146095 by tommylight
02 Oct 2019 02:11 #146847 by andypugh
Replied by andypugh on topic G code confusion
en.wikipedia.org/wiki/G-code
RS274
Specifically RS274NGC which was a version defined by NIST for EMC.
The following user(s) said Thank You: tommylight, Dinuka_Shehan
